I can only speak for my own setup which may not be relevant to all. Not quite understand why always receive feedback on most motion sensor not suitable for their toilet use. Actually a simple way is to
set a longer duration like 15min on your motion sensor will suffice, unless you want zhun zhun to off the lights the moment you stepped out (which is not necessary, like 10G broadband). I am using Aqara motion sensor for my store-room and philips Hue motion sensor in my toilet, both works really well. I find presence sensor that need to connect to a power point kind of overkill and not flexible in deployment.
And of course, I have also done my “extensive studies” that my family members do not pang sai and shower for more than 15 min (except my waifu set 20min)
Normally >15min is reading or play mobile games while pang sai, fell into toilet bowl or waste water while showering which requires prompt actions to “kiam pak” liao.
