Just like their fancy feature full pedestal toilet with heating, all kinds of spray patterns etc.I like Japan pana model than local design.
in Japan have more features and functions
Hi, sharing a link. I cannot claim true or not true.
RT to kW
https://www.rapidtables.com/convert/power/ton-to-kw.html
kW to BTU
https://www.rapidtables.com/convert/power/kW_to_BTU.html
1 RT = 3.516kW
1kW = 3.412K BTU
in short, 1 RT = 12K BTU
RT kW BTU are different ways to see cooling capacity in different region. Just like miles vs kilometres
It’s better to have a higher cooling capacity and operate with higher efficiency rather than a lower capacity and operating at 100% load. So its MKM85VVMG for system 4.
have used both daikin and starmex 12k single splits R410, in different rooms but at the same time. the current consumption of the starmex is higher in the catalog but set temp is always 24 for daikin and 25 for starmex, to achieve a similar coldness feel. the FCU blower strength is also stronger with the starmex.With regards to Daikin model 75 or Starmex 3H28VG or Panasonic 3XU28YBZ, Daikin has the lowest power consumption with 1x 9K/12K FCU among all 3 brands, at 0.22kWh
actually if you can install 2 compressors, a single split 12K and single 9k will be cheaper and have better redundancy, since they are independent.I agree with this. I am currently using a system 3 compressor but only connected to 2 FCUs (12+9) in my parent's flat and it's more than sufficient.
a thick curtain will be the most cost effective way to block. anyway unless you are going to switch on 24/7 the savings in power consumption might not make up for the reno you need to do to add a partition. assuming you need to partition 5m.
i would still use 2 FCU, but have the 9k one blowing at the location of the desk. so switch on both 18 and 9k to reach set temp, then have the 9k working alone. maybe can save some.
My old flat used system 3, the condenser can only placed on master bedroom below window.We live in a 3 room flat with only 1 area for mounting (kitchen side bedroom) and the other bedroom is common corridor. So cannot.
Ya lo. Agree sia. So pretty!I like Japan pana model than local design.
Local one the design is nice. Quality still not there. Think there is some improvement? But not enough. The concept is there. But the quality needs to buck up.I like Japan pana model than local design.
i guess what i am saying is catalog spec vs real life use is different, dont bother too much about it. this 0.22kwh might not even be what it is in actual use case.
maybe just to share that even for inverter the compressor can shut off completely and it does this quite often when the set temp is reach and when even at the lowest 1.4kw cooling is still too high. from the catalog 3H28 lowest capacity is 1.4kw with a single 2.5kw FCU running. for Daikin it is 0.8kw for a similar single 2.5kw running alone. but i know my starmex shuts off the compressor when set temp is reached for some time, so i guess not much diff power consumption in the end.Not disagreeing with you, it could be significant in certain situations.
For example if most of the time is 1 FCU running and 2 common room not running. Where the 2 common rooms are occasionally being used when guests or parents come over. It does make sense to look at how low it can go when on steady state.
of coz, most of the time the energy savings is not that significant
Daikin MKM75VVMG without 8.5A limitation.Also because currently i am using 9kx3. Would 12k+9k+9k be better than current setup in terms of cooling and efficiency? Paired with daikin 75 compressor
12k, I install on my dining area, this is cooler, eating steamboat no issue.with the 12k it will cool faster.
