Yes. Home office / Study area within living room. Exploring a half height partition wall with a foldable (upwards or bifold) glass.
To cool the entire living room with a 22-24k btu will consume quite a significant amount of electricity. So I wanted to explore the idea of having 2 units, 1 x 9k for the small study area and 1 x 18k for the remaining common living room area.
The length wise of the living room windows is so long that it is hard to add a door to conceal the opening to the study room. So probably might have to consider having it open as it is. One option probably is to install a corner fan to blow the air backwards (towards the FCU direction) where the 2 standing desks will be.
In terms of System configuration, looking at either System 4 / 5, or System 2 + 2 or 2 + 3. Trunking and all will also be a consideration since more FCUs means more piping and the trunking can be unsightly for so many pipes.
Need AC installer to advise before committing to purchase but somehow it's a chicken and egg situation where you only meet installer after you purchase the AC. And most salesman in departmental stores are not the best person to advise on how to plan.
Actually not true. Even after I bought from GC; I paid one installer for site survey and got another site surveyor to take a look and advise.
But may I confirm if your 4rm is 3 bedrooms plus living plus study needs to have cooling? Dining no need? If this is so, personally I would prefer 4+1 with the System 1 being in the study. Reason is living and study may use at the same time. System 1 would be more efficient compared to System 3/4 with 1 FCU running.
