Dynacore, PC THEMES, AFTERSHOCK, Dreamcore
michaelfun
Hi all,
Wanting to get a gaming PC for 15 yrs old son, for school work and gaming, thought of trying the SI instead of buying those branded like Acer, Dell, etc.
Anyone has any experience in getting a PC from Dynacore, PC THEMES, AFTERSHOCK, Dreamcore? which one is good?
TIA
tigerwoods
Hi all,
TIA
I have 3 AFTERSHOCK PCs for 2-3yrs no problem so far.
xtractor
Hi all,
TIA
For me, Dynacore since you can still bargain and ask for discounts if you buy bundle with them.
I recommend that you buy your item, choose your own part there and have them assemble it for you.
Get windows 11 or 10 pro online for $20
They also have built-in ready system u can buy online called Invader PC where u can choose to upgrade the part and included with 3 year warranty onsite if u are ok with it
s7460597
Your son is old enough to do his own research. Give home a budget and ask for 2-3 suggestions.
yusoffb01
Dynacore is quite competitive if you know what you want. they assemble everything for additional $30.
If you prefer on-site warranty with no headache, get aftershock instead. I have a friend who needed motherboard replacement. If buy from normal shops they dont care after you paid.
When you get older, better pay for warranty instead of the headache of taking time off to deal with distributors
michaelfun
while others are giving very informative and useful suggestions, you comment for the sake of commenting which is of no value at all.
michaelfun
thanks bro for your very informative comment!
michaelfun
thats very true, thanks bro!
michaelfun
INVADER
MASTER M08 | RTX 4060 | i5-14400F SGD $ 1,518.00
IM406014400F-M08-XF08
Intel
i5-14400F 2.5GHZ 10CORE/16THREAD 20M
ASUS TUF GAMING B760M-PLUS WIFI DDR5
THERMALRIGHT ASSASSIN X 120 R SE ARGB
KINGSTON FURY BEAST RGB DDR5 6000MHz 16GB(8GBx2)
ASUS DUAL GeForce RTX™ 4060 O8G TWIN FAN GDDR6
CRUCIAL P3 PLUS 1TB GEN4 NVMe M.2
SILVERSTONE ET650-650W V1.4 80+ BRONZE
INVADER TITAN T80 M-ATX CASE BLACK TYPE C
3 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 6 + BT 5.2
CREEPER ARGB LIGHT BOARD (A-STYLE – 24 PIN)
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
WINDOWS 11 HOME UNACTIVATED x 1
Ram Upgrade 3:
CORSAIR VENGEANCE RGB DDR5 6000MHz 32GB(16GBx2) CL36 KIT x 1
ADDITIONAL WARRANTY:
3 years desktop parts warranty(onsite pickup and return) x 1
POWER SUPPLY UPGRADE1:
CORSAIR RM750e-750W 80+ GOLD ATX3.0 x 1
RockaRolla
INVADER
Intel
3 X 120MM ARGB FANS
WIN 11 UN-ACTIVATED
OPERATING SYSTEM:
Ram Upgrade 3:
This is a very bad configuration for the price
For 1.5k with PSU and ram upgrades from Invader, you can get at at least a rtx4070/rx7800xt system, which will wipe the rtx 4060 aside
That additional warranty upgrade is not necessary as well
You can take a look at Master M19 (5600+RTX4070), Master M21 (5600+RTX4070S), M16 (5600+7800XT), these are in the 1.5k range after the same psu/ram upgrades
Chevalier
He may have come off as abrasive but I get the point he is trying to make. Make this a father-son activity and turn it into a learning experience for him. How to spec a PC out within a given budget, how to build it and set it up. Those are some of the core memories I have with my own dad.
My vote is to go with Dynacore as well. Get the bundle from em and ask for discounts.
More often than not, you will be able to get better parts for the price compared to system builders like Aftershock.
Gluck!
michaelfun
MANSA
MATX (Full Custom) SGD $ 1,860.00
Case: Montech Air 100 (4 ARGB Fans) - Black
Processor Brand: Intel Core Processor
Processor: Intel Core i5-14400F
Motherboard: Asus B760M TUF Plus Gaming Wi-Fi & Bluetooth (DDR5)
Cooler: Cooler Master Hyper T200 - Black
Graphics Card: Nvidia RTX 4060 8 GB - Gigabyte
SSD: Lexar NM790 1 TB Gen.4 - R:7400/W:6500
Additional SSD: No Additional SSD
HDD: No HDD
Ram (DDR5 Intel): Corsair RGB Vengeance 32 GB DDR5 6000 MHz
Power Supply: Corsair RMe 750 W 80+ Gold
Operating System: Un-Activated Windows 11 Home 64-Bit
RGB Fans: 4 ARGB Fans Included
RGB Lighting Strip: No RGB Lighting Strip
Custom Sleeved Cables: No Custom Sleeved Cables
Monitor: No Monitor
michaelfun
Gluck!
Before i even post this, i had exhausted my effort to check with my son and he had no knowledge on all these, either his group of friends, that prompted me to post here to get the best performance with a good price tag, instead of getting an off shelve brand like Dell, Acer, etc.
I really appreciate all the bros that contributed on the comments with points for me to look into(which i am sort of a know a little bit but not enough knowledge level) but his comment is a no help at all, sounding like those idiots who will tell u that sentence when they cant explain or blur as well but act clever, " u know what i mean, right?", "你知道我的意思, 对吗?”...who dont know our dad is a male.....
As much as possible, i would like to enjoy the moment of a " father-son activity and turn it into a learning experience for him" but unfortunately my inadequate knowledge still need lots of improvement for me to teach him(i have to teach myself first, lol) and i really appreciate all the bros that gave me tips and pointers basing from their own experience that i can make use to minimise hiccup time.
When u talk about Dynacore, are u referring to Invader(their side arm) or Dynacore itself? thanks for your advice!
NightRaven49
MANSA
HDD: No HDD
Why not Mansa?
this is an even worse deal than the first invaderpc config u inquired, since this is basically the same thing but $300 more expensive for no real reason. imo mansa is grossly overpriced, sure u can argue their service centre may be convenient but im not paying a $700+ premium for that.
guys, the AMD is cheaper than the INTEL, is AMD as equally reliable as the Intel?
yes, for gaming is similar and consumes less power too. if ur looking for i5 14400 as cpu, u can consider ryzen 5 5600 as it is very similar in gaming performance. i wouldnt touch 14th gen intel anyway, since it is basically rebranded 13th gen so ur paying more for effectively the same performance.
