doogyhatts
- Feb 13, 2018
Meow Motion remains the top AI creator for YT shorts that caters to both gender.
More model creators have begun fine-tuning their datasets for PixArt-Sigma.
A is alpha, E is Sigma.i saw got pixart A and E got what difference?
i still learning all the menus/managers.A is alpha, E is Sigma.
alpha is the initial release, sigma is the upgraded version.
@AikiBoy
Now that you understood how to use ComfyUI,
you can get output quality closer to Midjourney if you use PixArt-Sigma. Use this workflow.
Prompt adherence is not 100% though, so need to do inpainting using Fooocus.
in youtube you need 1000 subscribers to start monetizing. i am recently creating my own dalle3 slideshow on youtube too like doggyhats, must slowly build up one. i now only have 313 subscribers.can monetise liao?
sic your channel lolin youtube you need 1000 subscribers to start monetizing. i am recently creating my own dalle3 slideshow on youtube too like doggyhats, must slowly build up one. i now only have 313 subscribers.
He used Bing-Dalle3.photos generated by the checkpoints which are from SD1.5 to sdxl .. can use for commercial use meh?
monetizing is already commercial ?
how they know if the picture you used are generated or not.He used Bing-Dalle3.
Monetising YT channel is considered commercial.
Custom SD1.5 & SDXL models should be ok since they are not derivative works based on their respective base models.
YT has a section that you have to declare your video content is AI-generated under certain circumstances.how they know if the picture you used are generated or not.
so many AI pic video on youtube... how to trace the picture back to the app you used...
the picture got hidden codes, you throw into the ai app they know its their?
yup, microsoft says okphotos generated by the checkpoints which are from SD1.5 to sdxl .. can use for commercial use meh?
which to dalle now!!
i think most of the checkpoints are derivatives of the base models.
they used the base model and then just input a few hundred or thousands photos of their own to train.
chim, what hundred of photos to train?
if i dl a model, i keep using it, it become better? lol
Yes, checkpoints on Civitai are typically trained from the base Stable Diffusion (SD) model as the starting point. Here are the key points:
So in summary, while techniques like LoRA allow modifying the SD model in other ways, the typical workflow for creating new custom checkpoints on Civitai involves fine-tuning the base SD model through further training on curated datasets.
- The base SD model (e.g. SD 1.5, SD 2.0) serves as the foundation or "checkpoint" that is further fine-tuned or trained on specific datasets to create new specialized checkpoints.
- Training a checkpoint involves taking the base SD model weights and continuing the training process on a new dataset of images to steer the model towards a particular style, subject matter, or capability.
- This allows creators to specialize the general base SD model into more focused checkpoints tailored for certain artistic styles (e.g. anime, photorealism), subjects (e.g. portraits, landscapes), or other custom training objectives.
- Using the base SD checkpoint as the starting point allows the specialized training to build upon the broad knowledge and capabilities already learned by the original SD model.
- Some creators may use other pre-trained checkpoints besides the official SD releases as their base, but the common practice is to start from one of the official SD checkpoints and fine-tune from there.
So is like saying SD1.5 2.0 is the base.so what you are using is already trained with custom photos on the base model.
This is the typical process of training a checkpoint. You dont trained it, because you are already downloading the trained model from civitai or other sources.
Hmm... I see.i think most of the checkpoints are derivatives of the base models.
