MyRepublic fibre - Part 5
doki81
want to check, the hyperspeed 10gbps plan..web listed it's 59.99 per month. and it also sure top $50 to get a tp link be805.
is this mean my monthly bill now is 59.99 + 50 per month x 24 months?
hwzlite
this seems to be different from what was happening before -- that appeared to be congestion on their Equinix IXP links, which I assume was alleviated by perhaps shifting traffic bound for Cloudflare and Microsoft to PNI links. you wouldn't have had latency issues to hosts in MyRepublic's, StarHub's (transit?), or Singtel's (via StarHub) networks
on the other hand, what I saw yesterday (and also on the 28th and 26th) affected everything going through the gateway for my public IP subnet, which is... pretty much everything.
edit: would've looked like this instead (notice that latency doesn't increase for everything)
Cool, may i know which apps that generate this graph?
Wockets
The $50 top up is a one time payment only. Not recurring :D
bakasora
Anyone else getting error when trying to watch Twitch.tv? The chat can load but not the video. If I turn on VPN then video can load. like wtf
keny1st
anyone getting low download speed directly from ONT? but upload is fine.
Download: 5XX Mb/s
Upload: 9XX Mb/s
and also yesterday night 8-10pm I have spike latency as well
I have 2 x 1gbps, both are the same.
Is it common issues now? MR refresh the line before, but still the same.
zhongfu
They emailed me earlier today to let me know that "[their] upstream provider has made some changes", and it seems like everything's back to normal now. And that does indeed appear to be the case now:
Mach3.2
i mean good that they listened and rectified the fault, but they don't have their own monitoring systems to pick to this kind of issues meh? walau eh....
sumako
Download: 5XX Mb/s
Upload: 9XX Mb/s
i got the same issue like you. called the hotline and told them about the download speed. still the same
MRC
Hello just like to check with the existing customer for MR. Is the connection to China for the gamer subscription is still very good? If possible can do the tracert for the following below. I went down to their official shop but there issnt any computer for me to check it out. Thank alot.
tracert 1688.com
tracert alipay.com
tracert taobao.com
MRC
Forget to mention I am using M1 now and the ping is easily over 400ms, just now reached 600+ ms. Hear MR is the best for China connection but not sure if its still good now and is it stable. Thank you.
lobukong
MR is better than M1 but not good enough for gaming in China server.
Also gamer plan is $5 more expensive but it's only marginally better. I used uu booster or mudfish for FF14CN before, both performs very well and much better than direct connect.
MR (1G non gamer)M1 (1G)
1688.com261ms (50% loss)384ms (0% loss)
alipay.com312ms (75% loss)395ms (75% loss)
taobao.com258ms (0% loss)393ms (25% loss)
