Dogz
- Jul 16, 2003
Normally 禄逢冲破 indicates 化禄 clash by 化忌 from opposite palace. Some sect (should be 1 of the flying star) even indicate 禄逢冲破 as 双忌。禄逢冲破
1. 化祿星和祿存被對宮忌星所沖,另外就是羊陀火鈴空劫六煞星在對宮沖。
2. 化祿星和祿存坐忌或與六煞星同宮,為煞忌所破。
So the 化祿星 and/ or 祿存 must sit inside 命宫 to be counted? But 祿存 is already giap between 羊陀....
And quite frankly, I think it's almost near impossible not to clash based on the 2 scenarios above.
禄存 with main star 化忌 in same or opposite palace is call 羊驼夹忌,为恶格, from 古书. If 禄存 alone without main star worse!
Other 煞星,空劫,火铃,羊陀 coming to clash 会带来阻碍,不顺,困扰. Of cus no good, but not as serious as above. Unless they form out other type of 恶格.
You are correct, above u mentioned 羊陀 coming to clash should only for 化禄。
, a malaysian master call it 同花顺.
