ZhouXingXing
- Sep 7, 2008
yes can..Can ziwei doushu chart identify romance period for that person? And also period good for job change?
You referring to the palace that kena 禄逢冲破 right.so which palace's 3F4Z should I take reference from? The palace with 化绿 or 化忌?
If have to look at 2 sets of 3F4Z, then that's already 2/3 of the palaces![]()
example if you are referring to your career palace and there is 禄逢冲破, you have to look at the career palace 3f4z.
example 太阳庙旺, the good quality of the sun is very obvious compared to the 太阳落陷 (sun blocked by the clouds during cloudy days)So if I understand you right, all stars got good and bad points. If good quality, means good points more obvious and vice versa?
Good quality means bright?
so when 太阳落陷 (sun blocked by the clouds during cloudy days), the good quality of the sun is less or not obvious.
so 最重要的还是4化和吉凶星的彼此之影响.
He only indicate 1 and only information that is 寿星入庙,so whatever info i have just point out, in general for 命宫.
古书:入廟為奇,失數為虛
”斗數至玄至微,理旨難明,雖設問於各篇之中,猶有言而未盡,至如星之分野,各有所屬禍福深淺,壽天賢愚,貧淫正直,各有所司,不可一概論議。其星分佈一十二垣,數定乎三十六位,入廟為奇,失度為需,大抵以生命為福德之本加以根源為窮通之資•星有同躔,數有分定,須明其生剋之要,必詳乎得垣失度之分“
because of the above para, alot of 紫薇斗术学习者最容易跌死的地方,很多就疯狂的着迷星星的亮度 but actually it is not that critical.
