- Aug 8, 2012
If its a few iterations before, e.g. 12/13 then worthwhile, otherwise, imo changes/"upgrades" are minute.
Consistent ah… their iPad Air and iPad Pro also same. U wanna 120hz, prepare to pay more for better screen (similar to Samsung as well)16 series is basically 15 pro max with 60hz display.
I mean come mo Apple... 60hz still??????????????????????
Improve on your 120hz pls.
Apple: iTs NoT rEqUiReD aT tHe MoMeNt!16 series is basically 15 pro max with 60hz display.
Prioritize thinness at the expense of battery lifeNooooo.. the plus model battery capacity getting smaller? what the heck man..
I am perfectly ok with some thickness and weight..Prioritize thinness at the expense of battery life
Apple thinks thin phones are 'sexier,' but i prefer larger batteries for better life and durability, even if it increases thickness. this also allows for better cameras without camera bumps. the trend toward ultra-slim phones makes them more fragile and prone to bending lohI am perfectly ok with some thickness and weight..
most users will throw on a case, what is the point of making it thin like paper??
Well, I’m not you. But once I see 120Hz, I can tell for sure 60Hz is no go for me anymore.Don’t get the hype on 120hz display.
I was on 13 pro and upgraded to 14. No real loss imo. In fact after more 1 year of use my battery life at 97% which is fantastic.
