michael_thm
- Jan 1, 2000
A question... the BTO ceiling electrical hole (60mm diameter) is too wide for the mounting plate of my ceiling fan (distance between opposite bolt holes is 96mm), this mean that the drilled holes (diameter 8mm, 4 of them) will be just like 10mm from the electrical wiring hole. I reckon that this is too dangerous as the pressure from expansion bolts might crack the concrete.
Solution 1 = Move the mount off center so that only max of 3 expansion bolts can mounted. If necessary use a screw plate (with 2 holes... one hole bolted to ceiling and other hole for the remaining unused bolt hole)
Solution 2 = Waiting for EDMW DIY sexperts to recommend.
