Please log in and verify your age to view this post. Why?
Hi @xenotine just found your post. Did you manage to solve it? i have similar problem. Contacted support, but only ask to do system update and reset to factory settings, it solved for a while, but problem come back after that.Anyone got this issue where there is only black and white color when view via HDMI.
No issue when using patchwall, netflix, other mode (eg, TV)
it jumps to Google TV Home and flickering, it is not cable issue, it is more like the app keep refreshing. Usually restart the TV will solve the problem without touching the HDMI cable. But quite irritating to keep restarting every time it happens.Try pushing the HDMI cable in more
Sometimes it gets loose
Otherwise maybe it’s time to call the service guy…
I wasn’t addressing your issue bro…it jumps to Google TV Home and flickering, it is not cable issue, it is more like the app keep refreshing. Usually restart the TV will solve the problem without touching the HDMI cable. But quite irritating to keep restarting every time it happens.
Not solve . Most likely spoil and had since change to another xiaomiHi @xenotine just found your post. Did you manage to solve it? i have similar problem. Contacted support, but only ask to do system update and reset to factory settings, it solved for a while, but problem come back after that.
sigh.. never expect xiaomi so laoyaNot solve . Most likely spoil and had since change to another xiaomi
new one also give issue . Sometime after awhile screen will get jerkiness till subtitile cannot generate . Had to keep restarting .
bought from where ?sigh.. never expect xiaomi so laoya
official online shop in lazadabought from where ?
Xiaomi A Pro 2025
No dolby vision? My Q1 75" still have dolby vision, the display quality still very vivid. Was hoping they can up it's gamehttps://www.mi.com/global/product/xiaomi-tv-a-pro-55-2025/specs
quite underwhelming the specs
lesser ROM (8GB), only 1 USB 2.0 port (we are almost quarter century past Y2K and only still getting USB 2.0, and only 1 this time around)
only 2 X 10W speakers. No Dolby Vision?
and still the same CPU/GPU from 3 years ago.
so what's the powerful features this time around?
What's the size of the ram?
1gb or 1.5gb or 2gb?
