Xiaomi TV Discussion Thread VII [consolidated]
keegs
Hi, anyone have problems with Q2 TV when your source is from HDMI, the TV own self jump to PatchWall then keep flickering? I recently disconnected the TV from internet, the problem seems to be gone. But it defeat the purpose of getting smart TV. Anyone has solution for this or how do I replace the launcher to other good 3rd party launcher?
keegs
Anyone got this issue where there is only black and white color when view via HDMI.
No issue when using patchwall, netflix, other mode (eg, TV)
Hi @xenotine just found your post. Did you manage to solve it? i have similar problem. Contacted support, but only ask to do system update and reset to factory settings, it solved for a while, but problem come back after that.
petetherock
Moderator
Moderator
Try pushing the HDMI cable in more
Sometimes it gets loose
Otherwise maybe it’s time to call the service guy…
keegs
it jumps to Google TV Home and flickering, it is not cable issue, it is more like the app keep refreshing. Usually restart the TV will solve the problem without touching the HDMI cable. But quite irritating to keep restarting every time it happens.
petetherock
Moderator
Moderator
I wasn’t addressing your issue bro…
Maybe you need a factory reset
xenotine
Not solve . Most likely spoil and had since change to another xiaomi
new one also give issue . Sometime after awhile screen will get jerkiness till subtitile cannot generate . Had to keep restarting .
keegs
sigh.. never expect xiaomi so laoya
joesph
guile
Jurong640
https://www.mi.com/global/product/xiaomi-tv-a-pro-55-2025/specs
quite underwhelming the specs
lesser ROM (8GB), only 1 USB 2.0 port (we are almost quarter century past Y2K and only still getting USB 2.0, and only 1 this time around)
only 2 X 10W speakers. No Dolby Vision?
and still the same CPU/GPU from 3 years ago.
so what's the powerful features this time around?
No dolby vision? My Q1 75" still have dolby vision, the display quality still very vivid. Was hoping they can up it's game
