The AMD Zen 3 Ryzen 5000 Discussion Thread
Yongkit
I'm using a 5600x with 3060Ti card, 64gb ram. is there any point to upgrading to a 5700x3d? how many more fps can I expect?
Read HWZ Forum Rules!
Based on the current setup, the real benefits will be your 1% low improvement closely match to your fps, if you do not have the norm monitoring your 1% low there is no point upgrading except the extra 2 core 4 thread improvement for productivity usage.
Phen8210
AMD is scraping the bottom of the barrel to use up the below-spec silicon. :ROFLMAO: Should be a popular budget pick if the price is right. I'm on 6-core 4 GHz myself and my CPU does what I need it to.
well, it's always cheap on AMZ
local price cmi unfortunately, no matter which shop techyard scrapyard whatever
Mach3.2
@Yongkit @Mach3.2
The thermal conductivity of PTM7950 is insanely good, even when applied to an IHS on a CPU.
This setup is entirely silent in a non-meshed mATX case, with the top and sides covered.
Fans are 3 in 1 out setup, all running below < 1200 RPM.
The 5800x is paired with Scythe Fuma2 cooler with PBO values 107-72-105.
Testing was done at controlled temperature ambient 28c.
Single Core
Multi-Core
I never expected it to be this good. This ultimately beats anything that I ever tried.
The only downside is that the transition period took about 2 days to settle in after the first application. My initial results from 2 days ago were easily 10c higher than now. It can take quite a while to fill the gaps since it repeatedly goes from solid to liquid.
So the night after I cleaned my computer with a fresh application and booted up Horizon West at release, it went near 80c, and after about 30 minutes, it magically went down, which I found weird.
Just yesterday, I realized my CPU has never gone past 63c anymore while hitting the max boost clock. That's why I decided to run the test.
how is it now? performance still same?
Phen8210
It's still the same, not even a single bit of diff.
I just tested, and everything is within the margin of error.
It's quite insane that even after all this time, nothing has changed.
Also, I applied the PTM7950 on my laptop iGPU, using 780M.. the clock speed went higher, and I could draw higher power, which also fixed the issue I had with those sudden throttling that made my fps dip down.
pls dont buy this tim, so the cost can remain low, i scared it become popular n ppl start to buy
i got 80x80 piece, can use for awhile, I decide to use it for everything
KleoZy
If you are holding to a 5000 or 7000 series AMD processor. This may or may not happened but will still be good to update your bios.
https://www.pcgamer.com/hardware/pr...tem-flaw-but-its-pretty-difficult-to-exploit/
These are the fixes but not on 3000 series.
DESKTOP
CVEAMD Ryzen™ 3000 Series Desktop Processors
(Formerly codenamed)
“Matisse”
AMD Ryzen™ 5000 Series Desktop Processors
“Vermeer”
AMD Ryzen™ 5000 Series Desktop processor with Radeon™ Graphics
“Cezanne”
AMD Ryzen™ 7000 Series Desktop Processors
“Raphael” X3D
CVE-2023-31315No fix plannedComboAM4v2PI
1.2.0.**
(2024-07-30)
ComboAM4v2PI
1.2.0.**
(2024-07-30)
ComboAM5PI
1.2.0.1
(2024-08-07)
taken from AMD official website
Phen8210
DESKTOP
“Matisse”
“Vermeer”
“Cezanne”
“Raphael” X3D
1.2.0.**
(2024-07-30)
ComboAM4v2PI
1.2.0.**
(2024-07-30)
ComboAM5PI
1.2.0.1
(2024-08-07)
I wouldn't worry since many vectors of attacks need to be successful before this vulnerability can be exploited, but yeah still good to update.
nakedtons
Is AMD Ryzen 5000 series getting obsolete? I have people telling me I need to upgrade my PC cause I am using Ryzen 7 5700X even though I've only built it last year.
robolee
it is only obsolete when it doesn't meet your requirement :)
chiu2000
Obsolete in the sense that the socket is already a ded end, but Mama Su still have a lot of love for us. There are still new CPU coming out this year.
Phen8210
you thinking too much, they just finding ways to clear their e waste :ROFLMAO:
