Install Ubuntu 24 halfway after reboot
ouroboroso
Do you see the GRUB menu appearing at all?
Try holding down Shift during boot-up to get the GRUB menu to appear.
ouroboroso
Should be correct. As I didn't change anything.
Try rebooting and then hold down the Shift key while booting to see if that allows GRUB menu to show.
Otherwise it probably means your GRUB was installed on a non-bootable partition, which would require you to boot using the thumbdrive again and do a boot-repair to reinstall GRUB onto the right partition.
Lasogette
I actually got 22 on the partition. I reinstall a 24 thumb drive this time by wiping it out. Ke Yi like that ?
ouroboroso
When you do the 24.04 installation into the 22.04 partition, it will overwrite the existing one.
Maybe share your lsblk output if possible.
Lasogette
Now can reinstall liao. After I change the boot order. Try reinstalling again. Thanks.
Lasogette
Gxgx! Install Windows in KVM within Ubuntu, can get 99.9% bare-metal performance nowadays with some optimisation tweaks.
Ok sure will look into it soon. I use windows 10 and 11 I feel they doing something dangerous sia. Keep what to sync my data to cloud.
