No this time. It ask me to remove my thumb drive then enter. Enter liao jitau go into biosDo you see the GRUB menu appearing at all?
Should be correct. As I didn't change anything.Is your boot drive set correctly in BIOS?
I actually got 22 on the partition. I reinstall a 24 thumb drive this time by wiping it out. Ke Yi like that ?Try rebooting and then hold down the Shift key while booting to see if that allows GRUB menu to show.
Otherwise it probably means your GRUB was installed on a non-bootable partition, which would require you to boot using the thumbdrive again and do a boot-repair to reinstall GRUB onto the right partition.
Now can reinstall liao. After I change the boot order. Try reinstalling again. Thanks.When you do the 24.04 installation into the 22.04 partition, it will overwrite the existing one.
Maybe share your lsblk output if possible.
Haha ke Yi liao. But my windows disappear. But NVM la. I rarely use windows now.When you do the 24.04 installation into the 22.04 partition, it will overwrite the existing one.
Ok sure will look into it soon. I use windows 10 and 11 I feel they doing something dangerous sia. Keep what to sync my data to cloud.Gxgx! Install Windows in KVM within Ubuntu, can get 99.9% bare-metal performance nowadays with some optimisation tweaks.
Ya man. I duno they keep collect my data for what.Not to mention the super-frequent updates nowadays.
U also no use windows ?Not to mention the super-frequent updates nowadays.
