iPhone16/Plus/Pro/Pro Max Accessories Thread
ragnarok95
Senior Moderator
Senior Moderator
arphamdb89
Has anyone used before those cheap Shopee tempered glass? Planning to buy for my mum. I personally have not used any screen protection for quite many years.
runforyourlife
Moderator
Moderator
Ugreen SG website i only found Ugreen 90409 65W 2c1a 3Port Nexode Fast Charger and its $79.​
https://ugreensg.com/?product=ugreen-90409-65w-2c1a-3port-nexode-fast-charger​
This kinda price I might as well buy Belkin BoostCharge Pro 65W dual USB-C with PPSCourts supposedly selling $69 usual price $80.
https://www.courts.com.sg/belkin-wc...dual-usb-c-gan-wall-charger-with-pps-ip189547
No doubt Ugreen got an extra USB-A port but I can do without.
Just type 100w la.
luckygal
Ugreen screen protector is reasonably ok quality right? For casing, is it better to get those 4 corners with bump?
rubber33
Been using for 13 pm 14 pm 15pm. Cheap and good. Now 16pm I see price 9 dollars for 2 pcs. Thinking if sipgen quality any different? 25 dollars for 2 pcs.
ragnarok95
Senior Moderator
Senior Moderator
You prefer with black border so that the gap between the glass and the casing is smaller?
jianrong
Ugreen fast charger 100w can also use any usb c cable right? Or must use their cable?
