iPhone16/Plus/Pro/Pro Max Accessories Thread
garychengjw
Belkin. I only own their surge protector. Everything else are ugreen for me. My display port cable, internet cable, usb c cables, usb c docking, charger are all from Ugreen. Powerbank is Xiaomi. :s13:
i everything also ugreen. even iphone 16pm case and glass. :s34:
BradenHeat
:s22: most of the 16 pro. max cases are gone from spigen shopee
those looking for chargers, might i intro, https://sharge.com/products/pouch
using it for macbook pro charging on the go, with the Gan charger of 45 w
as for ugreen stuff, their nexode pro 65w slim is easily something i can vouch.
Shawny88
Will an anti-blue light screen protector distort the actual screen colors that I see on the phone?
ralliart_ray
being using the ugreen nexode 100W charger since launch. rly no horse run.
then again, if you wan buy well known brand. so be it, we are just recommending.
at the end, no electronics are deem safe. see your luck only.
me using it too, that brick if throw at people.... will be able to do alot of damage LOL
evilduxy
just get 100w charger to "play safe" / "future proof".
the price gap not that huge by looking at the ugreen ones.
oh ok thanks
The answer it it depends, some charger like Ugreen has C1,C2,C3 and usually the top port takes priority in providing the highest wattage available. The phone will negotiate itself with the charger so not much to worry. TLDR, if worry that you cannot get the highest wattage charging input, get 100W or 200W kind usually most of their ports are capable of pumping up to 45W on each port.
At the end of the day, its just charging faster or slower, nothing much to worry about.
ok sure thanks
Problem is your charger can output max 45w boh, usually lower or split when you charge multiple device. Unless is those 1 port 45w ok la
yeah the first port mention able to charge 45-60w n when use two together become 45w+18w
Rubick
Hooted a Hoda Sapphire SP for 16PM to try.
Finally below $50 for 1 piece haha
Jirachi
Still not able to find any matte screen protector without the black border 😭
Singrish
Ugreen SG website i only found Ugreen 90409 65W 2c1a 3Port Nexode Fast Charger and its $79.​
https://ugreensg.com/?product=ugreen-90409-65w-2c1a-3port-nexode-fast-charger​
This kinda price I might as well buy Belkin BoostCharge Pro 65W dual USB-C with PPSCourts supposedly selling $69 usual price $80.
https://www.courts.com.sg/belkin-wc...dual-usb-c-gan-wall-charger-with-pps-ip189547
No doubt Ugreen got an extra USB-A port but I can do without.
Kunkka
Is it the 3 pin one. Always shock me
VodkaPear
Check shopee n Lazada, uk ver with discount can get less than 50
