[Software Update] iOS 18.7.2 is out!
sk0065
Can remove the extra apps for those purpose
I realized that I keep pressing the convert button by mistake when I want to press zero.
because iOS 17, the zero is long one. I press the left side of that zero.
iosnewbie
Just updated my ip15pm to iOS 18.0. All my banking apps work. More interestingly, last time when I launch apps like CPF or ICA where after Singpass authentication, I will need to press the top left corner of the Singpass app to go back to the original app like CPF or ICA. After updating to iOS 18.0, Singpass automatically switch backs to the original app after authentication.
Jirachi
This has nothing to do with iOS. This is Singpass API issue.
duabuiji
updated yesterday. my issues here is the widget page does not always refresh correctly. sometimes it will show up as blank for the Fitness and FindMy widget. Others like Calendar is ok. Remove and re-add the widgets does not solve the issue.
I will have to swipe right then left again for it to show up.
Another one is the re-arranging the control center buttons is a bit buggy, but this is no issue for me since i don't customise is frequently.
Another one is "Game mode" does not always activate.
Hopefully 18.1 solves it.
Apart from the above, the update is welcomed.
Fellowes
SingTel don’t support RCS on iOS 18.0
When you tap Carrier, it will change to IMS Status and show messaging support details to the right. For example, if your carrier supports RCS, you'll see Voice, SMS & RCS. If your carrier doesn't support RCS, you'll see Voice & SMS.
kopi22
Where can I find the Carrier option? I’m on iPhone 12 but can’t seems to find the option.
punker
Click on Settings > General > About. Then scroll down to the section below “Network” and keep tapping to change
Fellowes
Sinch and Singtel have collaborated to launch the first Rich Communication Services (RCS) Business Messaging service in Singapore, marking a significant development in the communications landscape. This partnership aims to enhance customer engagement through secure and branded messaging solutions.
No wonder consumer side has nothing yet on iOS 18.0 RCS. Did SH and M1 enable RCS with iOS 18.0?
