GotBetrayed
- Mar 27, 2013
After update cannot login to Uob
Ok I tried again, can Liao.Can login UOB via 12PM
Calendar can pinch now.Like the way reminders is integrated in the calendar look.
if is andriod barring samsung, weeks to 3 daysAfter update cannot login to Uob
I realized that I keep pressing the convert button by mistake when I want to press zero.Can remove the extra apps for those purpose
This has nothing to do with iOS. This is Singpass API issue.Just updated my ip15pm to iOS 18.0. All my banking apps work. More interestingly, last time when I launch apps like CPF or ICA where after Singpass authentication, I will need to press the top left corner of the Singpass app to go back to the original app like CPF or ICA. After updating to iOS 18.0, Singpass automatically switch backs to the original app after authentication.
updated over OTA. so far quite smooth. first thing I did was turn off app labels, turn on dark mode icons
Where can I find the Carrier option? I’m on iPhone 12 but can’t seems to find the option.
Click on Settings > General > About. Then scroll down to the section below “Network” and keep tapping to changeWhere can I find the Carrier option? I’m on iPhone 12 but can’t seems to find the option.
