- Mar 22, 2011
isn't that under phone settings? shouldn't be telco that block it.Does the data roaming allow WiFi hot-spot?
Cos the person i'm calling told me what he did just now, now going to the beach and later dinner all these, tomorrow then come back.But how do u know the other person is in other country? I recently called a local number. He told.me he is in malaysia. I was not billed for the call.
Should be free since long time ago. Call.local.number should not be billed for IDD?Cos the person i'm calling told me what he did just now, now going to the beach and later dinner all these, tomorrow then come back.
Means you same scenario as me, call the number when the person is overseas, not billed
Your ST main line is 5G right. Yeah, it's how singtel set their priority level. Mvno gets lowest priority. That's being said, my data in tunnel is slow. Make noise to mvno also no use. They are also cannot do anything
Continue to feedback to them. At least they have a record.You were just saying no one say anything about ST. Then I said my piece and you say also no use. What's next in your playbook?![]()
Maybe overseas calls r now routed through IP telephony, so can give many free minutes compared to in the past? Just guessing.i remember last time, when one is overseas, when you call them, you will be charged for overseas call. Cos technically, the person is already not in local network but overseas.
Most probably. The person i called is using Simba. Simba always have free calls back to SG when overseas, most probably their calls are routed voip.Maybe overseas calls r now routed through IP telephony, so can give many free minutes compared to in the past? Just guessing.
make more sense than free IDD without adding anyMost probably. The person i called is using Simba. Simba always have free calls back to SG when overseas, most probably their calls are routed voip.
Don't recall this to be an issue.i remember last time, when one is overseas, when you call them, you will be charged for overseas call. Cos technically, the person is already not in local network but overseas.
Can't be phone problem. Because I port from Giga to Maxx then to Zym. Can't be Maxx and Zym simcard both got problem ma. So unlucky meh.borrow another sim card from ur friend or colleague or family and try? maybe phone problem? do a full reset of the phone?
How to be me problem? My 3 numbers port together. 3 numbers using different phone. Even my brother also ported to Maxx and got problem also. So how to be "me" problem?Confirm is a you problem if two networks still have the same issue right
go to their service center to sort it out quickest https://zym.sg/find-us/How to be me problem? My 3 numbers port together. 3 numbers using different phone. Even my brother also ported to Maxx and got problem also. So how to be "me" problem?
Then reinsert sim card and try again.Can't be phone problem. Because I port from Giga to Maxx then to Zym. Can't be Maxx and Zym simcard both got problem ma. So unlucky meh.
when you call a local number, you are charged from your local calls bundle -ie freei remember last time, when one is overseas, when you call them, you will be charged for overseas call. Cos technically, the person is already not in local network but overseas.
Buds2 Pro promo for all zym customers
Relax.when you call a local number, you are charged from your local calls bundle -ie free
when a person with local number picks up a call while roaming overseas, he is charged roaming rates
always been this way, dunno where you get your ideas from![]()
I have called people from SG when they were overseas and I have never been charged IDD ratesRelax.
Last time when I was on traffic light telco, when you call someone, you don't know if he or She is overseas, but when bill comes, you will be in shock. Since when I called overseas.
maybe not i weird. Last time i use m1, kena charged.I have called people from SG when they were overseas and I have never been charged IDD rates
eg for Singtel, to get charged IDD rates, you have to dial 001 or 019 followed by country code, then the phone number
you will never get bill shock if you dial any 8-digit local number from SG.
If the receiver is overseas and he answers the call, he pays for roaming, not you
you are weird![]()
