harky
- Jan 20, 2002
oh i see wrong loryes look at cut-off yield.
latest where u see is 2.78?
If it’s higher than your next best alternative yes.Is it still worth investing in t bills with cash, given the lowering yields? My first t bills from 6 months ago matured and thinking if I should bid for the next round or pivot to bank deposits with short term promos with 3+ % pa interest over 2-3 months.
9 days, not 1 dayIf it’s higher than your next best alternative yes.
but you wouldn’t know for sure until the auction is over.
so the question is whether it is worth sacrificing one day of yield to take a punt for you.
Why 9 days? Do you mean cause after maturity, the next auction is 9 days away?9 days, not 1 day
u need to initiate a refund if u want to do it "immediately"Need to seek some advice.
My T-bill using CPF-OA (thru DBS) has matured and the sum has returned back to DBS. How do I put back into CPF-OA?
THank you.
go to dbs banking website and select refund to cpf.Need to seek some advice.
THank you.
mine also returned today to my CPF OA, since I will not get any interest for this month already, if I bid for the one that opens today, I will still only lose 1 month of interest correct?go to dbs banking website and select refund to cpf.
but,
why dont apply t bill again ? if you return to cpf now, you forfeit this month's interest. if you apply again, you will forfeit one month interest in 6 month's time. i.e if t bill yield is more than 2.5%, more money for you.
assuming you keep on rolling 6m t bill, you will lose about one month interest, because there is a 14day gap between matured bill and new issue.mine also returned today to my CPF OA, since I will not get any interest for this month already, if I bid for the one that opens today, I will still only lose 1 month of interest correct?
lol cause rate came down a lot liao maSo quiet.....![]()
now around 3%, can shop around for FDs insteadSo quiet.....![]()
Eh, logic says that so long as it is above breakeven, then you will be better off? So just bid above breakeven? Provided the next auction happens before end of month for u to have time to refund if not successful?My T bill (using CPF OA) coming back on 22 Oct. Should I put it back to CPF or reinvest in another 6m T bills? Any advice? Thanks
I read from Seedly that the breakeven rate for 6m is 2.92% (1 mth lag). So means I shd bid for 2.93%?Eh, logic says that so long as it is above breakeven, then you will be better off? So just bid above breakeven?
The next 6m auction date is 24 Oct and issue date is 29 Oct. Can I still do the refund in time before end Oct? If I am not successful, when will the refund come back to my CPFOA?Provided the next auction happens before end of month for u to have time to refund if not successful?
You got factor in the fees?I read from Seedly that the breakeven rate for 6m is 2.92% (1 mth lag). So means I shd bid for 2.93%?
If u not successful u can refund on the auction date itselfThe next 6m auction date is 24 Oct and issue date is 29 Oct. Can I still do the refund in time before end Oct? If I am not successful, when will the refund come back to my CPFOA?
Thanks!
