[GPGT] Moi house going thru HIP, life without a toilet ish hard! :(
crimsontactics
We have to choose between having a temporary/mobile toilet (which cannot be used when they are working = in the daytime) or water to the kitchen tap. The kitchen is also narrow by design.
We chose the latter.
What's the reason Bro kw442? :(
crimsontactics
Did mine last year, cannot ask for more for that price. Hope everything is good for you, don't slam the toilet seat, the spring effect will be gone but within one year your can ask for replacement, wait till just before the one year up or before paying the bill.
I stayed with friends for the first 2 days, after I moved back to use the last room
Gxgx Bro fartking! :(
crimsontactics
I'm so glad mine was over last Wed (2/10).
We paid $4xx cash to have the default PVC pipes in both toilets upgraded to stainless steel ones;
You really need to be around for the last two days to confirm and ensure the fixture locations, test-run all the installed fixtures, find faults/defaults, and have them fixed/rectified.
Edit: I paid the worker $30 to fix two popped tiles in my bedroom (the short type at the bottom of the wall).
Gxgx Bro kw442! :(
kw442
Our kitchen is a narrow and long type so not much space for a mobile/temp toilet;
They also said the temp flexible PVC/plastic pipe can only support 1 water output (meaning can't connect it to both the kitchen tap and mobile/temp toilet).
van123
U got left over tiles from last time?
My toilet wash basin shifted out to kitchen not sure how for HIP
crimsontactics
I see Bro kw442... :(
kw442
where u buy the tiles to replace?
Self source or HIP contractor provide?
Reuse the popped tiles + 1/2 piece from the HIP contractor:
(I don't really care how it looks as long as it is fixed and furthermore, it is behind the door)
(Testing Imgur VS Postimages)
kw442
If you start on Thu, Fri or Sat then the HIP period will cross two Sundays (assuming no PH during the period).
