zym.sg Mobile (Singtel MVNO)
gapboy
Can share the faq? This is scary
https://zym.sg/faq/roaming-calls-sms/
7.
Incoming calls you receive while overseas, even if rejected, are billed at both the incoming call roaming rate and rerouted IDD call charges, rounded up to the nearest minute.
Singtel's billing is based on Call Detail Records, and these records show this usage was captured and billed correctly.
We understand that unexpected roaming charges can be frustrating, but it's important to remember that rejected roaming calls are still charged per minute. Unfortunately, we cannot waive these charges. We appreciate your understanding.
Arandalo
7.
What should be done then if we receive incoming calls when overseas? :unsure: Just don't answer the call?
Seems like not answering the incoming won't work if in USA or Canada and the call rings for more than 30 seconds.
Roaming voice call is charged on a per minute basis. For USA and Canada, call charges will be incurred after 30 seconds of ringing even if incoming calls are unanswered.
https://www.singtel.com/personal/products-services/mobile/roaming/smsvoiceroam
A7997A
What are you looking for ? Selectively answer call ? Or don't answer any call ?
If don't answer any call, you can enable unconditional call forwarding, or some phone/plans has option to block all calls.
Selective would be more tricky, I know for a fact that reject to voice mail for sure triggers the double international billing, but if no voice mail, not sure.
Arandalo
Selectively answer call. I will still want to be informed of an incoming call when overseas. Depending if it's important/urgent then I will decide to answer and pay the high billing minutes.
Mancunian2
I have been in HK and Japan, didn't answer calls and no charges whatsoever - Singtel main line
USA/Canada never tried before
these days I usually buy local tourist sim card and rely on whatsapp when travelling - to avoid bill shock
chopra
7.
Not this one wor. My wife rcv the charge even when she nv go overseas
everglide
There is a new 5GB roaming for Roam Smart 4G to JP/S.KR/TW/AU/CN/HK/MACAU/PH/VN.
I sign up like 2 months ago without it, will this be automatically updated to my plan?
Jurong640
If yours is not automatically upgraded, try whatsapp their customer service for it. They will likely give it to you.
It happens to my $10 plan when they upgraded mine to 200GB from 100GB
everglide
This will be so great. Thanks for the advise!
Mancunian2
last time, at Raffles Place high floor and East Coast Park, Singtel line sometimes will connect to Indonesian network resulting in roaming charges. I experienced before but luckily never got charged inadvertently
not sure if they waived charges for genuine innocent cases
but Singtel advised to turn off roaming while in SG
hereiam7788
the solution is easy, just manually set the network to sinktel instead of keeping the default 'auto selection of network' setting that it will not auto switch to other network..
ryuworks
is there actually real support for ZYM? Feels like the Whatsapp number is being manned by a single employee whose main job isn’t support and he/she only replies when he/she likes. Gotten half replies or no replies when I posted support questions, haven’t really had any of my issues sorted out at all.
dc7176
Upgraded ur plan as in you paying $15 now ? Or after a year they give 200gb plus the 5gb APAC roaming?
gapboy
for mvno support usually is either whatsapp / FB or email .. this is how they lower their costs of operation to give cheaper plans.
Their chats on whatsapp are quite responsive in the evening when i contacted them previously.
rey_85
Any review on zym mobile 4g or 5g plan ? How the reception underground , in NE line , EW line ?
Tedicious
Thei daily operations via WA closes at 10pm.
I try to contacting dem on various occasion at ard 9pm+, almost instant reply. So u can try that timing
