- Dec 27, 2007
Got a few but not sure can disclose yetTP-link GE800 ?
GE800 / GE650 / GE550
BE700 / BE550 Pro -highest speed in here tested with this device?hehe
This model the specs like same as be72pro. Same CPU same ram. Just the design different.One new China WiFi 7 router from Ruijie (BE68 Ultra).
锐捷天蝎龙勃版 BE68 Ultra, dual band BE6800, using "Luneburg Lens Antenna" technology.
Listed price RMB 699, launch price can be below RMB 599.
I can get tplink BE800 at 31x. And bE805 @ 24x... Should I get a set to try?
Hiaz.. I got scarred by BE550... Fxxking tonnes of issue.
Just received the BE6500 and got it set up. Currently on the 1000mpbs plan by starhub.1. Asus China version routers work well with local ISPs.
2. TUF-BE6500 has quad 2.5G ports, it is okay for MR 3Gbps plan.
3. I also do not like XD4 Pro as the mesh node even if you choose it because of the form factor. I will probably recommend TUF-BE3600 or even another TUF-BE6500 as the mesh node.
4. As long as your DB box does not block WiFi badly, the coverage should be ok. Placement is important.
https://www.asus.com.cn/store/gallery-476.html
TUF-BE6500 --> RMB 799
TUF-BE3600 --> RMB 499
is that the speed of 2.4Ghz band?Just received the BE6500 and got it set up. Currently on the 1000mpbs plan by starhub.
Previous speed test with my Google home was: 300mpbs (speed test done beside the router).
Now with the BE6500, speed is: 70mpbs (speed test done beside router).
any idea what am I doing wrongly?
Ahh yes, I just split the dual-band to single 2.4Ghz and 5Ghz.is that the speed of 2.4Ghz band?
Yeah man.. Ordered a set to play..TP-Link Archer BE800 should be a safe bet.
My BE88 just arrived yesterday and Xiaofan TB recommendation on SFP+ to Rj45 works well with the router.
But I have a weird issue with the AIMesh setup. I have the same setup for many years but rarely run into this.
BE88U is at the store room, the following AiMesh nodes are connected to Be88U via RJ45 through the patch panel in store room.
1) AX88 in living room
2) AX88 in study room
3) AX55 in kids room
The AX88 (2) and AX55 (3) appeared offline this morning. Same thing occurred last night as well but they came back online after 10mins. I had to remove them and re-add them. All routers are at the latest firmware.
Anyone experience similar issue? Appreciate any recommendations, thanks.
Which plan do you have? I also intend to get the BE88 to use with my GT AX6000 and RT AX88U.My BE88 just arrived yesterday and Xiaofan TB recommendation on SFP+ to Rj45 works well with the router.
