morimorimori
- Jan 8, 2004
Avoid intel 13, 14 gen for now. Don't know how long it will take for potentially defective chips to clear from inventory.
Agreed. Go with Gen 12. The uhd730 on it is perfect for media transcoding.Avoid intel 13, 14 gen for now. Don't know how long it will take for potentially defective chips to clear from inventory.
How would you advise going with Qnap qts/quts or truenas scale?
The post you showed that Kubernetes has been replaced with docker which is very good news. But not sure how that would fare in production. I'm using Qnap only for reverse proxy, crowdsec, openapp and arrs. What are your views on this?
Just happen on this thread as I am considering retiring my Synology ds1819+ as I am reaching capacity (20+TB used out of 24 TB) and performance is middling. Had a lot of struggles with iSCSI performance. I also tried their virtualisation station and container manager but CPU is always a huge bottleneck.
I plan to switch from VMWare to Nutanix Community + OKD for my homelab. But I will still need a NAS and I plan to house 1 copy of essential VMs in each (for example, 1 AD in NAS and 1 in Nutanix).
The recent Synology offerings are not promising and TrueNas looks to be a decent alternative to try. But I am struggling at finding a good chassis. I need a short depth rack mount or a tower that does not take up more than 4RU as that is the space left on my rack now. I just need 8 disk. i think i can do sufficient with them. I plan to run a SSD-based volume for my OKD persistent volume and a normal volume for my family photos/videos/ebooks/general archive (maybe with a SSD cache if performance doesn't do)
Any suggestions? My mandarin sucks so any idea how to navigate Taobao?
There should be lots of tower/desktop chassis out there offered by Jonsbo:
https://www.jonsbo.com/en/product/ComputerCase/NASMotherboardSeries.html
Short-depth rack mount chassis will require more DIY work and enhancements shared here:
https://forums.hardwarezone.com.sg/...etwork-upgrade.6341518/page-11#post-153069584
Extra enhancements shared here:
https://forums.hardwarezone.com.sg/...etwork-upgrade.6341518/page-17#post-154089625
Found only this so far. Looking at 13" deep chassis just to be safe (33cm)
https://www.alibaba.com/product-detail/Cloud-12-bay-hot-swap-server_1600153401048.html
Do N100 motherboards normally include the N100 cpu already?
Hi guys. I need some help with regards to remote access.
Currently I have Truenas running on a N5105. I have installed Nextcloud from the apps side panel in Truenas.
I'm able to access both Truenas and Nextcloud remotely through Wireguard vpn, which was configured in another machine that runs Home Assistant.
But just realised that in this setup, I'm unable to share a public nextcloud link to another person that have no access to my vpn.
I already have a dynamic dns service already setup in the Home Assistant machine and can access Home assistant remotely as well through this.
How can I also use the same domain name to access my nextcloud instance? What are the correct port forwarding settings to configure in my router?
I still have a great deal to learn about these networking stuff ; pardon my ignorance. Any kind of help or point in right direction will be greatly appreciated.
Some arbitrary details:
Machine #1 (Home Assistant)
-Ddns from duckdns up and running
-https://xxx.duckdns.org
Machine #2 (Truenas)
-local ip:
local.truenas
-nextcloud installed: local.truenas:nextcloud
