iPhone 16e/Plus/Pro/ProMax Discussions [No WTB/WTS/Flip]
What color are you buying?
  • iPhone 16/16 Plus (White)
  • iPhone 16/16 Plus (Green)
  • iPhone 16/16 Plus (Pink)
  • iPhone 16/16 Plus (Blue)
  • iPhone 16 Pro/16 Pro Max (Black)
  • iPhone 16 Pro/16 Pro Max (White)
  • iPhone 16 Pro/16 Pro Max (Natural)
  • iPhone 16 Pro/16 Pro Max (Gold)
galvin
Nice! G9N is supposed to be the top tier Samsung panel. Next time if you sell your IP16 in Carousell, can include this detail and set a higher base price.
Thought Samsung panels been taking a lot of flak recently over green lines the past few years?
KYOGRE
I tried this method many times but cannot it to generate the sysdiagnose file so I googled and found an easier way to run sysdiagnose using Assistive Touch.
Settings > Accessibility > Touch > AssitiveTouch > on
Settings > Accessibility > Touch > AssitiveTouch > Customize Top Level Menu
... and add new icon for "Analytics"
Now you can run sysdiagnose just by tapping a button on the screen.
How to view the file after I downloaded the PC? Thanks.
Thanks, mine is G9N on 16 Pro Max.
kashix
According to 小红书, this year for iPhone 16 Pro series, G9N is the best panel. Both G9P and G9N are good though, Samsung panel quite safe.
sallybee
If you got LG panel, maybe can go down to the service centre for display change to Samsung . Shouldn't be a problem
CyberTan
If it is quite safe, why would samsung users complain about the green line issue? unless Samsung used inferior amoled on their flagship phones.
kashix
I’m saying comparing to getting LG panels in screen lottery. Not referring to green line issues.
ash like snow
Normal to sleep with 87% battery and woke up with 78%? I killed all apps but I think I forgot to off Bluetooth only
kashix
So unless you got G9N, even the LG GVC is better than the G9P. The G9P is 4th tier in your list of 5 panels.
Seems not to be the case this year for iPhone 16 Pro according to XHS. China users scrutinise the screen more, My panel looks pretty good to me.
ragnarok95
Senior Moderator
Senior Moderator
Maybe if you compare beside G9N then it's another case. :D :s13:
Always the possibilities. :D
