No need to mesh. Able to have 5/6ghz in entire flat. Only bad 6ghz coverage in mbr bathroom. Haha. Router in living room.Now can try EB810v + HB710 mesh. Haha.
Or if not needed, just sell HB710 for a bit of profit.
Is this custom firmware locked to Starhub?Hopefully you still have S$192 left for TP-Link HB710.
https://www.starhub.com/personal/support/article.html?id=LfNB5odcBt0mTG6Pr7GSB7
I need more coverage on my home network with the TP-Link HB710, what can I do?
You can extend the coverage by purchasing another TP-Link HB710 or EB810v from StarHub. Additional units can be purchased at $8 per month for HB710, $15 per month for EB810v (for 24 months) during initial sign-up or cash & carry from our retail store and Hub Troopers at $192 or $360 respectively.
Where is the $29.55 plan? Only see the $45 plan on the website.
let me summon a portal for you:Where is the $29.55 plan? Only see the $45 plan on the website.
not sure the Wifi6 is HB710 as the preview is squarish.
* the signup link doesnt work in chrome, have to use edge though
usually for PC / NAS scenario.btw if i have no switch at home i dun really need dual 10g port ryt ?
1 10g wan port to ont good enough for now correct ?
dun think any home device got 10g lan port curently
yup my gaming device lan port not even 1g lan portPersonally I think 2.5G wired devices will get popular and most families may have no or at most one 10G wired device.
If the router has one 10G port and a few 2.5G ports, that may well be a good one to use for 5Gbps or even 10Gbps plan, if you do not have a plan to add a 10G capable wired device (PC or NAS). Example is like the earlier mentioned Asus RT-BE92U (one 10G port and quad 2.5G ports, triband BE9700, at the listed price of S$399.
On the other hand, it is a moot point for Starhub 5Gbps plan users now that you can get HB710 at S$192 with dual 10 G ports, or EB810v at S$360 with dual 10 G ports and three 2.5G ports.
Which option would u recommend? As I heard Nokia router and Beacon 2 is very badFor the Nokia ONR option, you can always add more Nokia Beacon 2 nodes in the rooms.
As for placement of wireless router, you do need to follow certain best practices to have better wireless performance. For example, do not put the router in a closed cabinet. Put the wireless router in a higher place with no obstructions.
Planning to switch to SH 5GBPS with the lowest upfront cost.
My current router is the AX88U. Able to keep this. I paid a lot of money to upgrade to that previously.
Simba states free installation charges for new broadband but when filling the form it states installation is chargeable. How to contact them?
Mine cannot sign up using existing starhub with no contract. Any one knows?any idea why new account can't sign up the $29.55 ONT plan. it keeps showing error. But when I used my family member (which already have a starhub broadband service) it shows able to sign up for additional plan. Thanks
