Why so many go for manuka honey when jarrah is the better choice?
  • Need someone to talk to?
The_King
question : jarrah honey TA58+ vs manuka honey UMF 8+, given it antibacterial, antiviral, anti-inflammatory and antioxidant properties. which is better choice and why?
https://chatgpt.com/: When comparing Jarrah honey TA58+ and Manuka honey UMF 8+ based on their antibacterial, antiviral, anti-inflammatory, and antioxidant properties, both are high-quality honeys with powerful health benefits. However, their differences in potency, active compounds, and overall therapeutic potential mean one may be a better choice depending on your specific needs.
1. Antibacterial Properties​
  • Jarrah Honey TA58+:
    • TA (Total Activity) Rating: The TA58+ rating indicates a high level of methylglyoxal (MGO) and other antibacterial compounds in Jarrah honey. Jarrah honey’s antibacterial power is particularly notable due to its MGO content, which is often higher than in Manuka honey. This suggests Jarrah honey TA58+ is very effective at killing a broad range of bacteria, including E. coli and Staphylococcus aureus.
    • Strength: Jarrah honey’s antibacterial properties are notably strong, often outperforming many other honeys, including Manuka honey, especially at comparable ratings.
  • Manuka Honey UMF 8+:
    • UMF (Unique Manuka Factor) Rating: A UMF 8+ rating is considered effective for general antibacterial activity, but it is lower than higher-grade Manuka honeys (e.g., UMF 15+ or UMF 20+). UMF 8+ indicates that the honey has moderate antibacterial potency, primarily due to the methylglyoxal (MGO) content, along with hydrogen peroxide.
    • Strength: Manuka honey UMF 8+ is effective against many types of bacteria, but it is not as strong as higher-grade Manuka or Jarrah honey TA58+, which can have higher MGO levels.
Verdict for Antibacterial Properties:​
  • Jarrah honey TA58+ is the better choice for stronger antibacterial action due to its higher MGO content and stronger overall antibacterial effects.
2. Antiviral Properties​
    • Antiviral Evidence: There is limited direct research on the antiviral properties of Jarrah honey, though it has shown some potential in lab studies. Its strong antibacterial and antioxidant properties may also contribute to its modest antiviral effects, but more research is needed to fully confirm its efficacy.
    • Potential: Jarrah honey may help boost immunity and offer some support in fighting viral infections, but its antiviral action is not as well-documented as that of Manuka honey.
    • Antiviral Evidence: Manuka honey has demonstrated antiviral activity in studies, particularly against Herpes Simplex Virus (HSV), Influenza, and possibly other viral infections. Its MGO content helps inhibit viral replication and prevent viral attachment to cells.
    • Potential: The antiviral properties of Manuka honey are better-documented in research, making it a stronger candidate for viral support.
Verdict for Antiviral Properties:​
  • Manuka honey UMF 8+ is likely the better choice for antiviral action, particularly due to its more established antiviral properties.
3. Anti-inflammatory Properties​
    • Anti-inflammatory: Jarrah honey is rich in antioxidants, which play a significant role in reducing inflammation. Its high levels of flavonoids and phenolic compounds contribute to its anti-inflammatory effects and its ability to soothe conditions like gastrointestinal inflammation, skin irritations, and chronic inflammatory conditions.
    • Healing: Its anti-inflammatory properties are also beneficial for wound healing, as it can help reduce swelling and promote faster tissue regeneration.
    • Anti-inflammatory: Manuka honey is also highly regarded for its anti-inflammatory effects, which help reduce inflammation in sore throats, gastrointestinal issues like ulcers, and skin conditions such as eczema and acne.
    • Oxidative Stress Reduction: Manuka honey's antioxidants help reduce oxidative stress, a key driver of chronic inflammation.
Verdict for Anti-inflammatory Properties:​
  • Both honeys have excellent anti-inflammatory properties, but Jarrah honey TA58+ may have a slight edge for chronic inflammation due to its higher antioxidant content, which plays a major role in reducing inflammation at a systemic level.
4. Antioxidant Properties​
    • Antioxidant Power: Jarrah honey is extremely rich in antioxidants, particularly phenolic compounds, flavonoids, and vitamin C. These compounds contribute to its high antioxidant activity, making it one of the highest antioxidant-rated honeys.
    • Health Benefits: The antioxidants in Jarrah honey help fight oxidative stress, which contributes to aging, cardiovascular diseases, and chronic conditions like cancer. This makes Jarrah honey an excellent choice for overall wellness and disease prevention.
    • Moderate Antioxidant Content: Manuka honey contains a good amount of antioxidants such as flavonoids and phenolic acids, which help fight oxidative damage and support immune health. However, its antioxidant capacity is generally considered moderate compared to other honeys, including Jarrah honey.
Verdict for Antioxidant Properties:​
  • Jarrah honey TA58+ is the clear winner for antioxidant strength due to its exceptionally high levels of antioxidants, which give it a stronger protective effect against oxidative damage.
Which Is the Better Choice Overall?​
For Antibacterial Action:​
  • Jarrah honey TA58+ is the better choice due to its higher MGO content, which provides stronger antibacterial action.
For Antiviral Action:​
  • Manuka honey UMF 8+ is likely the better choice, as it has stronger, well-documented antiviral effects based on research.
For Anti-inflammatory Action:​
  • Both honeys offer significant anti-inflammatory benefits, but Jarrah honey TA58+ may have the slight edge due to its higher antioxidant content, which helps address chronic inflammation more effectively.
For Antioxidant Power:​
  • Jarrah honey TA58+ is the better choice for antioxidant benefits, as it contains a much higher concentration of antioxidant compounds, which are crucial for fighting oxidative stress and promoting long-term health.
Conclusion:​
Jarrah honey TA58+ is likely the better overall choice for general health benefits, including stronger antibacterial properties, higher antioxidant content, and effective anti-inflammatory effects. Its superior antioxidant activity and potential broad-spectrum antibacterial action make it ideal for long-term health support, boosting immunity, and preventing oxidative damage.
However, if you’re specifically looking for antiviral benefits, Manuka honey UMF 8+ might be a better choice, especially for conditions like HSV, influenza, and viral sore throats.
For general medicinal use, Jarrah honey TA58+ offers a more potent and well-rounded profile, especially for its antibacterial, anti-inflammatory, and antioxidant effects.
ahnyaahnya
where you buy?
Jarrah at honey world is selling $59 with TA58
your Manuka UMF 24 how much?
Sorry I can't remember where I bought the Jarrah from. I think was NTUC but am not certain. Was years ago.
Oh my current Manuka is only UMF15. . I used to take UMF24... but downgraded this year cos so expensive 😫
The_King
based AI
$59 jarrah TA 58+ is better then Manuka of similar price.
The_King
organic Jarrah TA58+ vs Manuka UMF 24. list of pro and cons.
When comparing Organic Jarrah Honey TA58+ and Manuka Honey UMF 24, it's important to consider the unique qualities, benefits, and potential drawbacks of each. Both are premium honeys with distinct properties, originating from different plants (Jarrah trees in Western Australia and Manuka bushes in New Zealand). Here's a detailed comparison:
Summary Comparison:
AspectOrganic Jarrah Honey TA58+Manuka Honey UMF 24
OriginWestern Australia (Jarrah tree)New Zealand (Manuka bush)
Antibacterial StrengthStrong (but not as strong as Manuka)Very strong, particularly at UMF 24
TasteMild, earthy, nuttyStrong, distinctive, sometimes bitter
Antioxidant ContentHighModerate to high
Glycemic IndexLowModerate to low
Health BenefitsWound healing, digestive health, antibacterialWound healing, digestive health, inflammation reduction
PriceExpensive, less commonExpensive, but more commonly available
SustainabilitySustainable (organic)Sustainable, but production is more limited
Taste PreferencesMilder, more neutralStrong, acquired taste
Market AvailabilityLimited, harder to find in some regionsWidely available
Conclusion:
  • Choose Organic Jarrah Honey TA58+ if you’re looking for a honey with a more neutral taste, high antioxidant content, and a strong, yet less harsh antibacterial effect. It’s also a good choice if you prioritize sustainability and organic certification.
  • Choose Manuka Honey UMF 24 if you need a highly potent honey for medicinal purposes, such as treating infections or supporting gut health. Its well-documented antibacterial properties and global recognition make it ideal for those seeking the strongest therapeutic effects from honey.
Both honeys offer significant health benefits, but the choice comes down to your specific needs, taste preferences, and budget.
so i ask more since manuuka 24 is very strong as comapre to jarrah
Organic Jarrah Honey TA58+ vs Manuka Honey UMF 24. Antibacterial Strength in percent
Manuka Honey UMF 24:
  • Active Ingredient: The antibacterial strength of Manuka Honey is primarily attributed to Methylglyoxal (MGO). The UMF (Unique Manuka Factor) rating directly correlates to the concentration of MGO in the honey.
  • UMF 24 indicates that the honey contains about 829-1200 mg of MGO per kilogram (depending on the specific batch).
Organic Jarrah Honey TA58+:
  • Active Ingredient: Jarrah Honey has its own unique antibacterial compound, which includes hydrogen peroxide and other naturally occurring antimicrobial agents. The TA rating (Total Activity) refers to the overall antibacterial potency of the honey.
  • TA58+ means that the antibacterial strength of the honey is 58 times greater than that of a 10% phenol solution.
Comparing Antibacterial Strength (in percentage terms):
  • Manuka Honey UMF 24: The antibacterial strength of UMF 24 Manuka can be equated to a 10-15% phenol solution in its ability to fight bacteria.
  • Jarrah Honey TA58+: The antibacterial strength of TA58+ Jarrah Honey is equivalent to 58 times the antibacterial activity of a 10% phenol solution. This is notably stronger than typical Manuka honey.
Summary:
  • Manuka Honey UMF 24 has a very strong antibacterial effect, estimated to be in the range of 10-15% phenol solution.
  • Jarrah Honey TA58+ is even more potent, with 58 times the antibacterial activity of a 10% phenol solution, making it a stronger antibacterial honey in absolute terms.
Thus, Organic Jarrah Honey TA58+ has a higher antibacterial strength than Manuka Honey UMF 24 when comparing their potency in terms of phenol equivalency. However, Manuka Honey has a more established reputation and research base for its antibacterial properties. Both are excellent for medicinal uses, but Jarrah might offer a slightly stronger antimicrobial effect in some contexts.
Money no have
antibac means what?
U also not using it to cover the wound what.
U are eating it, and it’s going all going into the stomach acid….
Money no have
antibac means what?
Considers my question in the other way,
We, as human also need bacteria to thrive, there are good and bad bacteria in our body, u eat such a high dosage of antibac, it is akin to setting off a nuke, a blanket ban killing everyone.
Will it be good?
The_King
Royal Jelly simi 6% 10-HDA reh
Hw does it pit~?
:sick:
in short
Comparison Summary:
AspectRoyal Jelly 6% 10-HDAManuka Honey UMF 24Jarrah Honey TA58+
Active Compounds10-HDA, proteins, vitamins, amino acidsMGO (Methylglyoxal), antibacterial compoundsHydrogen Peroxide, other antimicrobial compounds
Main BenefitsImmune support, skin health, anti-inflammatory, energy boostStrong antibacterial properties, wound healing, gut healthAntibacterial, antioxidant, skin healing, gut health
Antibacterial StrengthModerate, but helps with general infections and inflammationVery strong, particularly at UMF 24, effective against serious pathogensStrong, comparable to Manuka in antibacterial activity
TasteNeutral, slightly sweet and milkyStrong, unique flavor, sometimes bitterMild, earthy, and less pronounced than Manuka
Health FocusOverall vitality, skin, hormone balance, energy, fertilityWound healing, digestive health, immune supportSkin healing, gut health, low glycemic index, antioxidant
PriceExpensive, especially at higher concentrationsExpensive, premium product with limited supplyExpensive, rare, especially for high TA ratings
Common UsesDietary supplement, skincare productsWound care, digestive issues, immune support, skincareWound care, digestive support, skin health, energy boost
AvailabilityLess commonly available, often in specialty health storesWidely available, many reputable brandsLess common, typically found in specialty or high-end markets
Conclusion:​
  • Manuka Honey UMF 24 is ideal for strong antibacterial effects and is widely recognized for treating infections and wounds.
  • Jarrah Honey TA58+ offers similar antibacterial benefits with the added advantage of a lower glycemic index and a milder flavor, making it a good alternative for those with blood sugar concerns.
  • Royal Jelly 6% 10-HDA stands out for overall wellness, immune support, and skin health, offering a broader spectrum of benefits beyond just antibacterial effects.
The best choice ultimately depends on what specific health benefits you are seeking. If you need a potent antibacterial agent, Manuka or Jarrah would be the go-to, but for overall vitality, energy, and **skin
ChenHoNam
How do you all consume honey ?
mix with water and drink ?
one spoonful every day ?
SimpliCity2k
Normally plain water
sometimes individual/timely preferences
like add to coconut water instead;
or squeeze some lemon/lime;
or even add a little salt
for taste & purpose~
replace ordinary sugar to one's daily tea;
salad/meal etc.
