🛞 My honest review of Hankook Ventus Prime 4
Shutterbox
After driving on Hankook 9ventus prime 4 for a month.. I'm happy with the grip, control and noise level.. felt just as good as pricier Michelin Energy XM and Bridgestone GR80 that I used last time.. and better than other tires I had from Nexen, Laufenn, Hankook..
Comparable good tires from other brands like Michelin, Bridgestone, Continental, Pirelli would cost more than $450, so I think I made a good choice..
To be fair, I find CPC7 having even better grip, but noiser
hachi
I consider giti as Sg brand though others will say China
But top up abit.. I ask for my size giti 205/55R16 $90/95 for several shops.
ES32 same size MIJ Yr24 $100 per Pcs. Exotic wheels. Cheap and good.
Dump my left 40% conti Uc6, suddenly it is so quiet.
tk
Davanti dx390, quiet and comfort tyres, 205/60/R16, 4 PCs at $284.77 after all the discount at shoppee.
Tempting price.. I understand Davanti tyres are made in china though.. and tyrereviews.com ranked them in the middle of the pack.. so they are probably good for non demanding users looking for cheap tyres
Shutterbox
any idea whether on par with cc6? cc7 19" dunno when will have...
Continental ranked CPC n CSC as their high-end comfort n sports range
Theres ultracontact, comfort contact, eco contact, etc.
I dunno how they're ranked
jasvonvios
I find them as good as any japanese comfort tyres. Demanding users should use sport tyres which are noisy and I can't stand it.
tk
focus1974
always wonder how tyre can improve FC...
anyway, TS tried China brand tyre before?
the less threads it has.. the more fuel efficient it becomes. hehe.
but TRY AT OWN RISK. This is not financial advice or life advice.
This type of things no need fret one. get a good grip tyre..
the fuel efficiency already determined when you ordered the car.
u think car mfg claim is 10km per litre, your mod ..can make it 12km per litre?
the difference might not be worth ur time.
kelvinti
I was being recommended by a shop to go for Cinturato P7 (P7C2) about $150 - $180 depending on the sizes for good grip and comfy!
That's quite a high price but of coz it is a Cinturato!
kelvinti
I have never really border so much about the extra or less of a few km of fuel consumption for my car.
I just drive and make sure the tyres I have give me good grip, low noise and comfy ride.
That is the most important of all.
Anyway, I pump 98. No no 95 for me.
tk
jasvonvios
