Oppo Find X8 Series
kEvinErd
Told u.. d9400 is efficient even based on reviews. And small phone with 5610mah battery. Battery life ain't going to be bad
Find X8 not exactly a small phone leh.. lol.
At least not an iPhone 16 Pro or Pixel 9 Pro small.
But the battery life posted by users does look good. I read that China phones are very aggressive in dozing apps, causing delayed notifications. Is that the case here huh?
kashix
My notifications so far quite instant. 16 Pro a bit too small. This one I feel also small phone. Lol.
kashix
Yes you are always right. Now is Dimensity expert. Hehehe. Ask you for advice can never go wrong.
Btw it does support Dolby Vision on Netflix.
KeYoKe
To me is smaller than the size i used and it is light. It is small compared to those 16 pro max, s24+ etc
No issues with notifications as well
kensim86
Any idea which apps can be debloated? The interface is so similar to Realme GT2 Pro, so I assume there are apps to be debloated
vibranze
I use their app manager to uninstall as many apps as possible, plus the combination of manual uninstall and disable the app if it can't be uninstalled. Just debloat the apps that you think you are not going to use it.
yamenaidepure
The silent mode (with vibration) on the alert slider doesnt seems to work on games and reminders, i still can hear game sounds and reminder notification. Any ideas?
tkte_85
silent mode is for calls and messages notifications. Game sound is counted as media sound(including music and video) and reminder is considered as alarm iirc
kashix
Is there a way to mute the phone without using the slider? Just use onscreen control or toggle?
tkte_85
huh its the special feature that was only on Oneplus all this while, which then some recent Oppos also had this feature. Buyers should have known this was a thing b4 they bought the phone
KeYoKe
Do not disturb mode lor. Quick settings got a toggle.
Wierd that u wan to unlock screen to mute the phone when the side alert slider can achieve it directly. U come from iphone what, should know that it is very convenient
kashix
iPhone different cause it's action button. Press can le. This one need to slide up and down. A bit troublesome to me.
KeYoKe
U double standard leh. Before iphone 15 pro max, also slide up and down :s22: u also never complain what
Also, u rather slide up and down or u lock phone > slide down quick settings panel > toggle it on. U choose lor
kashix
I never toggle the iPhone mute button before leh. All alone is assistive touch, mute from there.
garychengjw
in before safe exit.
garychengjw
@KeYoKe so you cannot say I double standard .... I apart from 先上车后补票 ... I also 一视同仁 ...
it double standard, iphone had the manual swtich before action button. it works same purpose.
