The BE230 might go faster, but my MacBook Air M3 is actually maxes out at WiFi 6E. Macs don't seem to have adopted WiFi 7 yet. As of now, WiFi 7 USB adapters for the Mac are still very expensive so no point trying that.
I will bite on switching to China routers since the total acquisition cost of all three of my BE230 is only $240 (MR and Carousell) and I can actually sell them off for same or more. Which WiFi 7 dual band China router do you recommend for 3Gbps plan where I need two mesh nodes (3 routers in total) with 2.5Gbps wired back haul to cover all the rooms? Since I'm tied to MR 3Gbps for the next 2 years, I'm just looking to increase current WiFi speed to over 2Gbps from 1.2-1.6Gbps near field currently with BE230. Mine is an Apple household with Macs and iPhones, but I expect Apple to go to WiFi 7 in the next year or true WiFi 7 USB adapters from China become cheap. Not yet clear if Apple WiFi 7 devices will allow 320 MHz channel because to my understanding that's what prevents BE3600 devices from going over 2Gbps real world speed.
Actually WiFi speed of 1600 Mbps consider very fast and user must reserve some bandwidth for other devices like camera, smart TV, smart things etc and other user within the household.Sorry but it is practically not possible to hit above 2Gbps WiFi speed using 5GHz band. So China WiFi 7 router is not a solution for your requirement. 320MHz channel bandwidth is only supported on the 6GHz band.
And none of the Apple devices can hit above 2Gbps WiFi speed anyway with any router, including top of the line WiFi 7 routers. This is a limitation of Apple devices as of now. They are lagging behind. Apple iPhone 16 is a WiFi 7 device with 6GHz band, but it does not support 320MHz channel bandwidth and 4096 QAM, so the speed is limited to 1.6Gbps as well.
Let's see if Apple can come out with better WiFi 7 device next year.
Thanks. Are there any USB-c WiFi 7 dongles that can achieve over 2Gbps real world speed near field with any router?
Looks like I'll stick with the BE230 mesh for now. I'm getting 2401 Mbps Tx Rate (theoretical) and MCS 11, but it will be interesting for me to max out my 3Gbps connection when reasonably priced ($100-$150) 6 Ghz routers are available and Macs adopt WiFi 7 fully
My existing SH 1Gbps plan is coming to an end soon and considering to switch to ST 10Gbps.
As I read this thread, I'll like to clarify does ST provides ONR (superadmin login?) which end-user is able to bridge, or ST provides ONT as practised in the past? Please pardon me if I'm confused as I try to catch up with the earlier posts.
Currently, I have a switch that connects to my router and links to the distribution panel, and to the LAN ports in the rooms. Does this setup works the same when I switch to ST 10Gbps, assuming ST provides a ONR and I connect the switch (disregards it's a 1Gbps switch) to it and links to the distribution panel?
Next, I will also use my existing ASUS mesh for my wireless devices. Does it work with ST ONR or I need to use ST mesh?
There is a rumor saying that that SingTel has changed the DHCP server behaviour and your ONR MAC address is registered when you first register and get the DHCP from SingTel DHCP server. Basically only the MAC address of the ONR will work with Singtel DHCP server.
This will basically kill ONR bridge mode because after bridge your own router connected to the bridge port will not get the IPv4 address.
For those who cannot bridge the Singtel ZTE F8648P ONR, maybe this is the reason.
Let's wait for more reports to see if more and more people are getting affected. Or this is just a temporary experiment from Singtel side.
I was also suspecting SingTel DHCP server changes previously when I was not able to bridge the ONR back in mid-August. Once I bridged one port, I would lose internet access. This could be explained that the DHCP server only allows single MAC address from the ONR to have internet access. Once they detect that you are requesting the second public IPv4 address from the DHCP server, they would cut off your internet access. Luckily I was able to bridge the ONR in late Oct 2024.
If we based on existing reports, Singtel issued ZTE F8648P super-admin login info is as following.
User name: support
Password: reverse of the root password printed on the label
However, there is a report saying that SingTel may have changed the passwords for new ONRs, no longer the reverse. This will basically kill the bridging as well unless someone figures out the way to get the new super-admin password.
It drops off pretty fast so by the time it goes through 3 walls, it's reduced from 1.6Gbps to about 200Mbps on the other side of the house. Hence the BE230 Easymesh with 2.5Gbps wired backhaul is crucial to restore the speed everywhere. All the smart things, cams etc are on the 2.4Ghz IoT SSID. Only issue is that mesh satellite routers can't seem to carry Guest and IoT networks. Only the main router can. I actually have to have a cheap Xiaomi 2.4Ghz range extender just to extend the IoT network, which is nuts.Actually WiFi speed of 1600 Mbps consider very fast and user must reserve some bandwidth for other devices like camera, smart TV, smart things etc and other user within the household.
Because it is big house so quite common issue.It drops off pretty fast so by the time it goes through 3 walls, it's reduced from 1.6Gbps to about 200Mbps on the other side of the house. Hence the BE230 Easymesh with 2.5Gbps wired backhaul is crucial to restore the speed everywhere. All the smart things, cams etc are on the 2.4Ghz IoT SSID. Only issue is that mesh satellite routers can't seem to carry Guest and IoT networks. Only the main router can. I actually have to have a cheap Xiaomi 2.4Ghz range extender just to extend the IoT network, which is nuts.
Noob question to decide if 5 gbps Starhub or 6 gbps M1 is sufficient rather than 10 gbps.
If one has a wired connection to router, what is the fastest speed (best case scenario) would get for:
- Uploading & downloading files from OneDrive
- Updating Mac OS
I actually worried about this when I read Dong Knows review of Easymesh. But it turns out in Oct 2024, Easymesh firmware was introduced that addressed his two main concerns in terms of features: 1. Lack of AP mode and 2. Wired backhaul. With Easymesh AP mode, you can use an ONR without bridging mode and connect one of the TP Links in AP mode as the Easymesh controller. You no longer have to have an Easymesh router as the primary router. As you mentioned, wired backhaul, deals with the issue of bandwidth in wireless backhaul on a 2 band WiFi 7 router.Unfortunately, TP-Link EasyMesh is still half baked and not as good as TP-Link Deco Mesh in terms of feature and maturity.
Thanks but doesn’t say how fast it goes up to if there’s a cap.Maximize upload and download speed for OneDrive
https://support.microsoft.com/en-us...06d-997b-98ab6ff67f43?ui=en-us&rs=en-us&ad=us
See thisThanks but doesn’t say how fast it goes up to if there’s a cap.
This speed is possible but not consistently.Screenshots for the TP-Link BE230 to MR 3Gbps on MacBook Air M3
- Updating Mac OS
