- Oct 8, 2010
as expectedFrom Whatsapp with Singtel
"Sorry, every recontract now with existing ONT will be automatically changed to GPON ONR or if it's 5G or 10G plan it will be XGSPON ONR.
...as expectedFrom Whatsapp with Singtel
...From Whatsapp with Singtel
Also, we don't have 1Gbps Plan anymore it's obsolete.
Your current plan will still continue even if you don't recontract.
Currently, it's $40.65/mth once the contract ends you will be charge for the usual price of $53.89 per month."
Requested to be transferred to the retention dept to try my luck. Still waiting after 30 minutes.
Think maybe the CS forgot about me already.![]()
Continued after 24Hrs...
"Hi there! This is XXX from Home Department. Apologies, we no longer provide ONT. All of our broadband plans come with ONR.
Unfortunately, we do not provide for recontract as well. For recontract, if it's 2gbps, we only provide wireless router/mesh. If it's 5/10gbps, then we provide XGSPON ONR (which supports 5/10gb network)."
So...ITE liao! Not sure if Home Dept is related to retention dept or not though.
thanks for sharingContinued after 24Hrs...
Thanks for sharing! Seems like ONR is inevitable.Continued after 24Hrs...
I did re-contract. I even have the contract agreement from 2022 to 2024 and paying $39.90 (now is $40.xx after GST increase). I even collect the new router. LOLSo you have been paying a higher subscription rate these 2 years? Or you actually forgot to re-contract?
When you recontract, you should receive the contract agreement via email then.
If you have been paying the higher subscription, you can use the contract the ask Singtel to refund you the difference. No saying they will definitely do it but you can try.
I believe this is normal.
You were using an ONT, so they have configured this ZTE ZXHN F620 ONR in ONT mode for you, only LAN 1 is working and not the other LAN ports (LAN2/LAN3/LAN4). Since it is no longer an ONR and the ONR itself has no internet access, so the INTERNET LED is OFF.
This has been reported before. It seems to me Singtel has run out of the old ZTE ONT for some time and now they use the ZTE ZXHN F620 ONR configured in ONT mode for ONT replacement.
Reference: if the ZTE ZXHN F620 ONR is in ONR mode, then the internet light should be ON.
https://www.singtel.com/personal/support/broadband/routers-ont/zte-zxhn-f620
You can carry out an experiment to connect a PC to LAN 2 and it will not have internet access if the F620 is in ONT mode. The PC will have internet access if F620 ONR is configured in ONR mode.
that's normal...Anyone experienced this or similar before please share your experience here.
1) If you re-contract, your ONT will be changed to a new ONR.Singtel offer me 2GB Mesh with a pair of wifi6 mesh (either askey or Arcadyan)
I have few question
1. my router is ONT, can I continuce to use it?
2. which model is better - askey or Arcadyan?
I have few question
Singtel offer me $39.26.mth. $1 cheaper then what i'm paying for 1Gbps ($40.65) lol1) Will need to change to ONR, cannot use ONT.
2) both mesh solutions are very lousy.
BTW, what is the price of your 2Gbps recontract offer? If it is S$39.90 then maybe considered not a bad offer if you don't mind using SingTel ONR.
Typical SingTel 2Gbps recontract offer is at S$37.90 to S$39.90 per month with one wireless router. If you can use Ethernet backhaul, the wireless coverage of two mesh nodes will be better than single node anyway.
This is my personal experience of upgrading from SingTel 1Gbps to 5 Gbps.My concern is .. while waiting for Singtel technician to install the ONR. there will be a period when I'm using my 1Gbps setup for 2Gbps plan. will it have any issue?
- ONT will be changed to ONR. No need to return the ONT.
- For the upgrade, SingTel will activate the second port on your Fiber Termination Point (FTP) in your home. This 2nd port will be used for your new plan.
- They promise no downtime during the upgrade (this is important to me as i work from home), but this is not true.
- On the actual day of the installation, before the SingTel installer comes, there will be a slight downtime where you have no internet - i suspect this is when they de-activate your existing port 1 and activate port 2 (but this is just my speculation).
- Once the installer arrives and connect the ONR, your internet will be restored. All in all, my downtime was less than 30 minutes, but to be safe, i requested for an appointment after my working hours.
