Philippng
- Sep 14, 2021
Bros, i am not aware of about singtel tv box. I use starhub before and from the ont. One port go to the router the second port is for starhub tv box.Which Asus router?
Typically you need to enable Singtel VLAN and usually LAN4 is for the old Singtel TV box (VLAN ID 20).
You can try to connect the new Android TV box to this LAN port to see if it works or not. If it works then the new Singtel Android TV box needs to use VLAN ID 20.
If not, connect it to the other LAN port and see if that works. If that works, that means the new Android TV box does not need VLAN ID 20.
I believe one of the above should work.
If that still does not work, then get an old Singtel issued router to see if that works. If that does not work, call Singtel for support. If that works, then that is strange and you may have to contact Asus for help (but I doubt they can support in that case).
Based on the user guide, I believe it should work with both Singtel ONT and Singtel ONR. But Singtel will not support 3rd party router like Asus.
https://www.singtel.com/content/dam...tv/documents/new-singtel-tv-starter-guide.pdf
Could it also be the same with singtel
