Oppo Find X8 Series
kashix
This battery ok boh?
SOT not so much but the standby time is impressive haha
Mclairs83
To be honest mine also not very impressive. I still need to charge daily as Android auto on wireless suck a lot of battery
But overall better than my ip13pm.
hstreamy
Do these steps few rounds and see any improvement,
Setting-apps-app management -click the 3 dots on top right corner -show system - battery- clear data-clear storage usage- charge to full (repeat for few rounds the steps)
Sendai
By the way, just to check are you all using the default sms app from the phone? There seem to be no option to click block number in it
hstreamy
Theres no screen protector available for x8 pro?
Am using this type, not bad the AR
【淘宝】7天无理由退货 http://e.tb.cn/h.Tf0liXp8B6uJvcR?tk=wJAW3xtAUAQ CZ3456 「适用OPPO findx8proAR抗反射保护膜AR护眼菲林光固膜findx7ultra手机膜降反射降反光增透膜findx6膜高清钢化」
点击链接直接打开 或者 淘宝搜索直接打开
vibranze
For the stock launcher, I found that I can't put an icon above the dock, it will auto moved to the very top, is this a limitation or I need to configure something to do it? Thanks.
hstreamy
Maybe can try to untick icon autofill in the home screen and lock screen setting
maumu
first time touching the x8 series at Starhub shop today.. the normal x8 feels like an apple 🙄
x8 pro looks fine but camera specs like not really that good, they're just depending on AI zoom to enhance the images?
missyflo
Woohoo…Finally ordered X8 from Lazada flagship. There’s $120 voucher to offset (12.12 sales). Tomorrow last day.
Any apps that I can transfer all my setting and apps from s24 ultra to Oppo?
