- Dec 27, 2007
SOT not so much but the standby time is impressive hahaThis battery ok boh?
your's is X8 or X8 Pro?To be honest mine also not very impressive. I still need to charge daily as Android auto on wireless suck a lot of battery
But overall better than my ip13pm.
Do these steps few rounds and see any improvement,To be honest mine also not very impressive. I still need to charge daily as Android auto on wireless suck a lot of battery
Quite solid battery life there
I'm using the Google Messages as a default app for SMSBy the way, just to check are you all using the default sms app from the phone? There seem to be no option to click block number in it
How much now?Whoaa non pro getting cheaper and cheaper.
$977.90 after coins and $130 voucher from dv tech. Freebies still availableHow much now?
Really cheaper sia but ok la, still got it at a good price$977.90 after coins and $130 voucher from dv tech. Freebies still available
Am using this type, not bad the ARTheres no screen protector available for x8 pro?
Maybe can try to untick icon autofill in the home screen and lock screen settingFor the stock launcher, I found that I can't put an icon above the dock, it will auto moved to the very top, is this a limitation or I need to configure something to do it? Thanks.
Thanks, it works!Maybe can try to untick icon autofill in the home screen and lock screen setting
