May I ask is this the correct setup.Yes, M1 is using XGS-PON ONT for its 3Gbps/6Gbps/10Gbps plan.
M1 ONT -> Ubiquiti Dream Machine Pro Max -> POE+ injector -> U7 Pro.
is there anything lacking that I need to purchase?
Thank you.
Thank you.
I think this is the one.Any ideas if PoE injector is speed rated?
https://sg.store.ui.com/sg/en/products/u-poe-at
I got the item but yet to sign up any plan. Therefore unable to try.The PoE injector seems rated gigabit but U7 Pro port is 2.5Gbps. Can update on the connected speed is 1Gbps or 2.5Gbps if you get this PoE injector?
Hi, currently on $31 ish plan M1 500 mbps that is no longer available for new users, should I go with another ISP or request for the same plan to recontract? My priorities are absolute cheapest, maximising the quality I can get from the $30 budget I intend to set aside for. I've had no issues with stability with M1, though I see more options nowadays offering 2.5G and 10G at that price.
Would also prefer not to have to pay extra porting fees if going to change ISP.
Just stay with the same plan, no need to recontract, the price should keep the same at S$30.45 per month for M1 500Mbps plan.
I actually decided to keep my Starhub 500Mbps plan (no contract since Sept 2020, at S$30.45 per month) and not to go for the Starhub 5Gbps special offer at S$29.55 per month, since it is good enough for the use case (not my main Internet line).
Ok, M1 has sneakily made me pay around $40+ per month when I forgot to recontract years ago. They claim that was the usual price without contract.
I think M1 made the change last year, only for M1 500 Mbps plan.
For M1 1Gbps plan, recontract price is at S$40.65 per month now --> they basically push you to upgrade since M1 2.5Gbps plan is at S$39.90 per month and M1 3Gbps plan is at S$40.90 per month.
https://www.m1.com.sg/home-broadband
Hmm, didn't starhub say the new plan price will not change after contract expires on their website. If so might as well get the 5gbps?Just stay with the same plan, no need to recontract, the price should keep the same at S$30.45 per month for M1 500Mbps plan.
But why? I'm kind of mystified by this. Wi-Fi in typical multi-dwelling home settings in Singapore cannot even come close to sustaining 10 Gb/s even if some large download could otherwise be delivered that fast from a remote server in the cloud. You might even get only a single digit percentage of 10 Gb/s over Wi-Fi depending on your neighbors, what they're doing, and what you're doing.....My plan is to have the best Wi-Fi coverage for my whole house with a 10 Gbps plan.
1. If I take M1 plan which cost $63.90 per month, can I continue using my AX88U to make Ai Mesh with the BT10 ?
2. The BT10 second unit need to use wire backhaul to mesh or use wireless to do the mesh ?
3. If to sign with Whizcomm and buy BQ16 (Single pack) at a later time, is it better than BT10 (Twin pack) given my home sq area ?
Yes, even a wired hop over coaxial cable (with MoCA 2.5 adapters; easy to find) or telephone wire (with G.hn Wave-2 adapters; harder to find) is likely to deliver better overall results than a wireless hop between Wi-Fi access points. Use whatever preexisting wiring you've got if you can.2. I will suggest using wired mesh backhaul whenever possible. Both for stability and consistency.
Amen.10Gbps plan is not going to miraculously provide you the best WiFi coverage. There is not much link between the two. I will think 3G is sufficient even for high-end WiFi7. Best WiFi coverage is still about your AP placement and backhaul.
Is this price going to increase once the contract ends?Updated on 21-Dec-2024
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html (Special offer 5Gbps plan at S$29.55 per month, ONT, you have to get your own router).
How long is the contract?
Does it come with ONT?
My Singtel legendary 1 Gbps plan had expired on Monday and now looking for a new plan. Had read the first page of this thread and 10 Gbps is on my mind. My current home network configuration is as follows:
Singtel ONR + Asus RT-AX88U + Asus AX3000 with Ai Mesh without wired backhaul. The AX88U is at the wall in between bedroom and Living / Dining. The AX3000 is at the Bedroom just beside the living / dining.
I have 2 options for 10 Gbps plan. Either M1 or Whizcomm. M1 comes with the Asus Zen Wi-Fi BT10 pack. Whizcomm is sign plan and buy 1 pack BQ16. My house is 90 sqm Punggol BTO bought in 2011. I have some considerations as follows:
Unable to sign up. Stuck at loading screen, tried on 3 different browser also cannot. Have tried to clear browsing data also cannot.Please go to the following thread for more details about Starhub special offer at S$29.55.
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-5gbps-plan-launched.7024290/
1) You may get different answers but many claim that the price will remain the same after talking to Starhub.
2) 24 months contract.
3) This ONT option comes with only the ONT. You have to use your own router. Or you can get TP-Link EB810v (S$360) or HB710 (S$192) from Starhub. Both are 10G capable triband WiFi 7 router and belong to TP-Link service provider model.
