yokine3a
- Aug 20, 2008
So you confirm will pick 1 unit if chencharu got balance? Very lousy unit also take?if i got go this round... i will advise u next month.![]()
Not confirm. got to do some survey on noise pollution for lvl 2.So you confirm will pick 1 unit if chencharu got balance? Very lousy unit also take?
me forgot liaoFor flat booking, i just need to bring
1. NIRC
2. Invitation letter (show the security guard)
3. Annex (go there print)
4. $500
Correct?
Let me know if you make it to hdb for flat selection chencharuif i got go this round... i will advise u next month.![]()
Dun think cani read 1 person post.... more than 10, can appeal to waive.... dunnoe real anot.![]()
See your comfort level. I stayed level 2 for several years last time, below got whole row of shops. Human talking noise not really that bad, vehicle noise was worse, car horns very irritating.Not confirm. got to do some survey on noise pollution for lvl 2.
Can I know did you includes your mum's particulars when applying this BTO? If you included your mum as a occupier in this BTO. I think you got a good reason to ask them to waive if only type 1 flats are available. Some of the HDB staffs are quite understanding. Likely won't kena banned for 1 year.i read 1 person post.... more than 10, can appeal to waive.... dunnoe real anot.![]()
NRIC and annex ownself print.For flat booking, i just need to bring
1. NIRC
4. $500
Correct?
Huh you can go hdb portal see mah the type 1 and 2 units taken. Is the samethey should split type 1 and type 2 applicants.... very obvious people don't want type 1. rubbish hdb.
Most applicants will take type 2 over type 1.Huh you can go hdb portal see mah the type 1 and 2 units taken. Is the same
How ur mum can stay with you if only left type 1 to choose?Most applicants will take type 2 over type 1.
For every 10 applicants, 0~3 applicants will take type 1. The majority still prefer type 2. (even low flooring)
If don't have units.. chu go new bto ?they should split type 1 and type 2 applicants.... very obvious people don't want type 1. rubbish hdb.
2 single bed . Can put .How ur mum can stay with you if only left type 1 to choose?
Renting out presents another set of problem
i will go for woodlands.If don't have units.. chu go new bto ?
