OnePlus 13 series
progene
i post all the options here
Hopefully, the price is attractive....
KeYoKe
The pre order period is from 7 Jan to 17 Jan so delivery will be after 17 Jan ?
Correct. Dispatch on 18th, so delivery 19th onwards. Cannot wait just go Mistermobile. They should have some physical stocks ready on 8th Jan
I had find x8, i find picture quality more or less the same. I didnt pixel peep though. But processing of image is the same, cos same hassleblad branding
Bro do you know 13R pricing?
849 :s13:
SuperDecker
849 :s13:
849 for 12/256gb seems okay. But it's like a downgrade from my X8 chip to 13R's 8 gen 3 although it's way much powerful for my use. Wait for reviews. Seems like everyone aiming OP13. But can't find tg for it easily..
KeYoKe
Ya. Actually thats the only thing holding me back... Since u have find x8, just hold out a bit more ba
tkte_85
its still curved screen, so finding TG is as difficult as other curved screens. I'd rather go hydrogel based as per my usual recommendations to go Marina Sq HP Inspirations. And if u have X8, just continue using it, no reason to keep changing unless u hand itchy or techie that keep changing phones
eddy0505
What's your unhappiness with x8 that your even compelled to change to op13/13R? 13R is definitely a downgrade, it's like Xiaomi T series to their flagship ranges. Other than a more powerful chip, I would think that OP13 is a very minor upgrade to OP12.
