OnePlus 13 series
-Synchronicity-
So die die must use their charger to get 100w? If my 3rd party charger supports 100W, OP13 won't reach that rated charge?
tkte_85
It has always been the case, same for oppo and realme, this 3 are cross compatible. Xiaomi vivo Huawei and honor also have their own charge tech. Your 3rd party charger I assume is those PD ones, those are more for laptop use, though some phone brands do make use of PD like Nubia
limmk
Gonna sleep tonight instead of watching :s13: cos i finish playing with the phone le hahahaha
Moi can hear the laugh
Dr Evil Laugh GIFs | Tenor
SpicyBird
i think it's their "orange" usb cable. charger should be the same across all brands bah....
qrcode
Side note: can always buy from Mistermobile from 8th Jan onwards. Limited physical stocks will be available if one is lazy to wait for shopee, lazada preorder as those will only be dispatched on/after 18th Jan
MM shop has the local/global set? or flashed from China set?
qrcode
Time to upgrade phone: Honor magic 7 pro / oneplus 13 / Samsung galaxy S25, all will be launched one by one
qrcode
What you currently holding bro?
S22 Ultra, used to hold OnePlus 5T (still working as my spare phone). Never use Huawei (Honor) phone b4. I even don't Honor phone is using Play Store or Huawei store.
KeYoKe
local honor magic 7 pro will be global set with playstore
Oh, oneplus 5T is quite some time back liao. but do research on the "new" oxygenOS compared to the one on Oneplus 5T ah
