OnePlus 13 series
kashix
Lol I hooted as well
Wah what color?
actually tbh, my 6t is still relatively smooth today, just that the 128 storage is like at 97% which cause the occasioinal lagginess feeling unless i clear cache, but other than that it still good to use. for a 7yo phone from oneplus. if only more people know about Oneplus.. other than samsung and apple
Ya hahaha, I went through a few OP with @KeYoKe over the years. Think my first OP was OP 3T.
Nice la bro, but my question is how much better is the display compared to pixel 9 pro, coming from someone who used both? :o
Also 顺便 ask about the haptics compared to pixel 9 pro also, thanks.
I don't really have much love for P9PXL during my usage, neutral feeling but not a bad phone. I'm still using P9PXL for work. Haptics wise, most of the reviewers got nothing but praises for OP13, I have no complains with it. Personally still feel iPhone haptics is the best, don't know how to explain, the 感觉 is very good. But display quality wise, I think is the best so far, if display non Dolby vision content, I think it's the best display so far, might even be better than 16PM.
KeYoKe
Wah what color?
Our 情史...... :s13:
Loser
Wah what color?
High praise from you, means dxomark anyhow rank it number 39 for smartphone displays. :s13:
KeYoKe
Wah what color?
Try the o haptics in settings la, and crank up haptics to max. Let the haptics impress u
kashix
OnePlus 13 DisplayMate A++ Rating and Best Smartphone Display Award​
Based on our extensive Lab Tests and Measurements the OnePlus 13 has a Very Impressive Excellent Top Tier World Class Smartphone Display with close to Text Book Perfect Calibration Accuracy and Performance that is Visually Indistinguishable From Perfect. Based on our objective Scientific Lab Tests and Measurements the OnePlus 13 receives a DisplayMate Best Smartphone Display Award Earning DisplayMate’s Highest Ever Display Performance Grade of A++ and setting or matching 21 Smartphone Display Performance Records including 10 that are Visually Indistinguishable From Perfect that are listed above.
The display really looks good leh, I like sia!
Sometimes review really anyhow, like if you go XHS/weibo to see FX8 review, they say the display is damn jialat/will cause irritation to eyes/red-eye/blinding. I used it for 1 month, no special discomfort leh, made me nervous before I bought it ... I even go check my eyes before and after using the phone, no diff leh ..
I don't like too strong also, must be just nice ...
KeYoKe
That's not enabled by default one ah?
By default isnt maxed out. It is like 3 to 4 notches down.
O haptics is the video where they flex their haptics btw. Not a feature :s13:
You also max it uh? Bro any tips and tricks for OP? You long-time user liao.
Just max it or adjust it slightly stronger. I maxed it out and no complaints at all. Alot of us agreed that haptics on OnePlus has surpassed iphone level le
Loser
Good to see haptics given attention from OEM.
KeYoKe
Dont say that... X8 has 2 display manufacturers iirc. You might have won the lottery OR your eyes not susceptible to eye fatigue ba. You using iphone for so long, they are stuck at 480hz afaik.
kashix
X8 only got Tianma panel mah? I got do research one! X8 Pro is the BoE panel, the better one.
tkte_85
haha long term user but casual techie level at best, nv go that deep into things like haptics etc nor able to compare it to iphones etc. Prob some or alot of users here are more familiar with functionality or where things are located even
KeYoKe
Yeah I vaguely remember it's both. There is another major manufacturer TCL (should be hua xing) in China.
OP13 and 13R both using BOE right?
Which display mode you all using?
Ya TCL
Op13 and 13r is BOE. 13 for sure is BOE, 13r initially no idea, then saw on OnePlus website using X2 material, then i know is BOE
Am using vivid
