Hi guys, I am a M1 broadband user and using the standard Huawei ONT M1 installed for me years ago.
The ONT has 4 Ethernet receptacles but when I plug into the empty ones that I'm not currently using nothing seems to happen. no internet comes out from those. Can I check if anyone knows if only one of the ports in the ONT works? Do I need an extra network switch if I want an Ethernet point from the ONT?
ONT only port 1 working. Meant to connect port 1 to your wireless router WAN port.
Other ports, as you have found out, does not work.
If you need more ports using switch, you need to connect it to the Lan port of your wireless router to get internet.
You cannot connect port 1 of ONT to switch and get internet in every ports of the switch.
Only 1 port in the switch, the one that connects to a device first, will have internet.
ONT do not have router function. Are you not using a wireless router too?
