- Mar 22, 2011
Speed test, around 1.2m away from BE805, using Samsung Galaxy S24 on WiFi 6E 6Ghz band.
Tested against Campana server.
Oh, i was confused when you commented in SH thread that you got SH 5gbps plan, when I remembered you have Singtel 5Gbps plan. haha
What's the use case for using the router as AP mode instead of the main router?
Is it like those BTO's where the main router is placed beside the TP point in the box? Then wired up to living room for the BE805?
Oh. So the router like BE805 will be just for wireless clients, while your OpenWRT is like a modem with advance features like NAT, without WiFi features?No, I have OpenWRT as my main router with more features than Asus or TP-Link wireless routers. So I use the wireless router as APs.
What's the benefit of using OpenWRT before router like BE805?
Please loan me your be805. Let me try 2x Be805 Easymesh with my Oppo Find X8 pro. If good, I will sell away my Asus GT6![]()
Before that I will try out Archer BE805 + HB710 to see if EasyMesh Wireless Backhaul works fine or not.
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.16 ms (jitter: 0.58ms, low: 2.79ms, high: 4.58ms)
Download: 4822.49 Mbps (data used: 2.2 GB)
2.41 ms (jitter: 19.67ms, low: 1.58ms, high: 223.81ms)
Upload: 4978.25 Mbps (data used: 2.4 GB)
7.12 ms (jitter: 0.56ms, low: 3.48ms, high: 8.42ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/51ff68b5-2b92-4d8a-9018-a407d8b4772a
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.23 ms (jitter: 0.69ms, low: 2.90ms, high: 4.48ms)
Download: 4617.89 Mbps (data used: 3.3 GB)
10.76 ms (jitter: 13.86ms, low: 3.63ms, high: 243.85ms)
Upload: 4669.31 Mbps (data used: 2.6 GB)
6.75 ms (jitter: 0.91ms, low: 3.25ms, high: 20.05ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/e95067ee-da9f-492e-b262-313c0988d586
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.31 ms (jitter: 1.00ms, low: 3.05ms, high: 6.17ms)
Download: 2204.27 Mbps (data used: 3.8 GB)
12.87 ms (jitter: 11.86ms, low: 3.50ms, high: 372.62ms)
Upload: 1254.28 Mbps (data used: 757.5 MB)
20.17 ms (jitter: 7.90ms, low: 6.43ms, high: 246.58ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c017a45e-29b4-47b3-a45b-8b1d73a19a8d
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.74 ms (jitter: 0.62ms, low: 3.44ms, high: 5.50ms)
Download: 1978.64 Mbps (data used: 2.3 GB)
14.45 ms (jitter: 6.38ms, low: 4.06ms, high: 33.06ms)
Upload: 1250.40 Mbps (data used: 1.3 GB)
11.54 ms (jitter: 9.33ms, low: 4.00ms, high: 240.93ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/1efd6949-5734-49dd-98cc-b5065ada4144
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.43 ms (jitter: 0.99ms, low: 4.95ms, high: 7.26ms)
Download: 611.09 Mbps (data used: 880.1 MB)
28.60 ms (jitter: 18.82ms, low: 6.66ms, high: 149.76ms)
Upload: 509.18 Mbps (data used: 906.6 MB)
38.33 ms (jitter: 27.84ms, low: 8.72ms, high: 393.45ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c3dd8e79-f6ef-4cc0-8a78-7f2878f8c70c
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.25 ms (jitter: 0.31ms, low: 4.71ms, high: 5.54ms)
Download: 645.67 Mbps (data used: 358.6 MB)
24.79 ms (jitter: 8.42ms, low: 7.03ms, high: 58.61ms)
Upload: 438.18 Mbps (data used: 411.7 MB)
28.48 ms (jitter: 24.13ms, low: 6.59ms, high: 296.11ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/254c46ae-7375-4d62-b8bf-a4d358b69af0
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.47 ms (jitter: 5.95ms, low: 5.81ms, high: 17.92ms)
Download: 121.48 Mbps (data used: 178.8 MB)
46.90 ms (jitter: 24.80ms, low: 7.39ms, high: 154.42ms)
Upload: 76.58 Mbps (data used: 122.6 MB)
639.08 ms (jitter: 89.68ms, low: 14.94ms, high: 1823.01ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/8464d770-364c-420f-9466-998158287a8a
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.88 ms (jitter: 0.62ms, low: 3.68ms, high: 5.48ms)
Download: 2500.70 Mbps (data used: 4.3 GB)
13.09 ms (jitter: 5.82ms, low: 3.57ms, high: 35.01ms)
Upload: 1319.84 Mbps (data used: 1.2 GB)
18.71 ms (jitter: 3.42ms, low: 8.25ms, high: 31.22ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/0a001dc1-8ac7-4e0c-91fd-5cb0ed10f124
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.40 ms (jitter: 2.00ms, low: 4.85ms, high: 9.18ms)
Download: 2015.74 Mbps (data used: 3.4 GB)
21.90 ms (jitter: 9.03ms, low: 6.21ms, high: 234.36ms)
Upload: 1141.23 Mbps (data used: 1.9 GB)
14.40 ms (jitter: 14.04ms, low: 4.02ms, high: 334.45ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/477eb7ec-da69-4521-b343-31c5ac1bac23
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 6.92 ms (jitter: 0.92ms, low: 5.99ms, high: 8.09ms)
Download: 2139.76 Mbps (data used: 2.4 GB)
23.77 ms (jitter: 7.59ms, low: 6.49ms, high: 46.49ms)
Upload: 1326.69 Mbps (data used: 1.4 GB)
22.53 ms (jitter: 3.04ms, low: 8.72ms, high: 31.07ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/3aac3feb-6455-4ce6-8a1e-355ceff33411
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.03 ms (jitter: 0.28ms, low: 4.79ms, high: 5.29ms)
Download: 665.37 Mbps (data used: 420.4 MB)
24.75 ms (jitter: 9.13ms, low: 7.71ms, high: 44.28ms)
Upload: 672.02 Mbps (data used: 752.4 MB)
18.87 ms (jitter: 8.31ms, low: 5.48ms, high: 251.58ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/aec720df-e1a4-486d-889f-bb4e1e13c8c7
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 12.73 ms (jitter: 10.86ms, low: 6.20ms, high: 37.63ms)
Download: 169.99 Mbps (data used: 233.9 MB)
41.84 ms (jitter: 17.61ms, low: 6.49ms, high: 79.78ms)
Upload: 153.61 Mbps (data used: 171.3 MB)
85.57 ms (jitter: 29.35ms, low: 9.46ms, high: 453.79ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/7bd28488-42b6-4897-b1c4-f529188292df
Indeed. My quick test shows the coverage is not as good as my Asus RT-AX86U and Asus TUF-BE6500, but still decent. This is kind of expected.
I will carry out more coverage related tests over the weekend to compare with Asus RT-AX86U and Asus TUF-BE6500.
6GHz coverage may not be good -- so I tested 5GHz coverage using my older Acer Swift 3 laptop early 2021 model (Intel Core i5-1135G7 CPU, 16GB/512GB) with Intel AX201 WiFi 6 adpater in this quick test.
TP-Link HB710 router in the living room.
3m away in the living room, strong signal on the 5GHz band
6m away with one thick wall in between, common toilet, still quite good signal on the 5GHz band.
This is an 1998 HDB flat so the walls are thick and can block WiFi signals quite effectively.
8m away with two walls in between the laptop and the router, weak signal on the 5GHz band. The results are not as good as the two Asus routers.
HB710 router, Acer Swift Go 14 2024 model (Intel Core Ultra 5 125H CPU, 16GB, 1TB, Killer BE1750 WiFi 7 adpater based on Intel BE200 chipset).
8m away with two walls in between the laptop and the router, weak signal on the 5GHz/6GHz band.
5GHz vs 6GHz vs 5GHz+6GHz MLO at far range ==> all speed data are not good. 5GHz is actually the worst, probably due to more interferences from neighbours in that area (service yard, on top of the washing machine).
2.4GHz/5GHz SSID --> connected to 5GHz band
MLO SSID, 5GHz+6GHz MLO
6GHz SSID
Asus RT-AX86U router, Acer Swift Go 14 2024 model (Intel Core Ultra 5 125H CPU, 16GB, 1TB, Killer BE1750 WiFi 7 adpater based on Intel BE200 chipset).
8m away with two walls in between the laptop and the router, weak signal on the 5GHz/2.4GHz band.
I consider 2.4GHz to be useless for main devices like laptop or mobile phone myself. For me 2.4GHz band is only for legacy devices or IoT devices (but I am not into IoT devices myself).
5GHz SSID
2.4GHz SSID
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.77 ms (jitter: 0.24ms, low: 3.56ms, high: 4.54ms)
Download: 162.97 Mbps (data used: 208.2 MB)
44.49 ms (jitter: 37.76ms, low: 3.84ms, high: 553.06ms)
Upload: 81.45 Mbps (data used: 112.9 MB)
438.51 ms (jitter: 97.18ms, low: 8.07ms, high: 892.35ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/ca37df21-bbc9-4910-ba3f-668b7e677da9
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 5.01 ms (jitter: 1.17ms, low: 4.15ms, high: 7.66ms)
Download: 167.47 Mbps (data used: 232.9 MB)
43.21 ms (jitter: 34.68ms, low: 7.54ms, high: 320.71ms)
Upload: 19.12 Mbps (data used: 34.0 MB)
141.69 ms (jitter: 48.75ms, low: 10.37ms, high: 594.05ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/8d17b3b6-6916-4ba9-a837-c4c7017f5398
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.41 ms (jitter: 49.58ms, low: 3.35ms, high: 103.19ms)
Download: 6.27 Mbps (data used: 12.2 MB)
109.98 ms (jitter: 75.75ms, low: 3.42ms, high: 1167.06ms)
Upload: 30.64 Mbps (data used: 50.1 MB)
226.46 ms (jitter: 74.65ms, low: 9.36ms, high: 1276.48ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/11c52e4b-c028-4a14-96e3-089f4b84be3f
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.46 ms (jitter: 2.60ms, low: 4.17ms, high: 13.88ms)
Download: 50.15 Mbps (data used: 77.0 MB)
56.10 ms (jitter: 46.58ms, low: 5.28ms, high: 1063.74ms)
Upload: 8.15 Mbps (data used: 14.0 MB)
118.28 ms (jitter: 52.46ms, low: 8.93ms, high: 849.64ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/30d71d8e-79b3-425a-85ba-47bbc34895b6
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 12.37 ms (jitter: 15.89ms, low: 3.94ms, high: 48.03ms)
Download: 46.30 Mbps (data used: 73.7 MB)
91.10 ms (jitter: 56.38ms, low: 3.99ms, high: 994.03ms)
Upload: 6.81 Mbps (data used: 8.9 MB)
198.12 ms (jitter: 61.10ms, low: 10.01ms, high: 828.73ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/383eaa0b-a0c1-422a-9c81-5c1b20456402
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 14.33 ms (jitter: 8.41ms, low: 4.80ms, high: 18.61ms)
Download: 75.12 Mbps (data used: 111.5 MB)
76.57 ms (jitter: 46.01ms, low: 4.25ms, high: 329.46ms)
Upload: 8.42 Mbps (data used: 13.8 MB)
179.70 ms (jitter: 63.19ms, low: 21.11ms, high: 1789.40ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/e7458d49-d9a7-4c62-ab19-1cb1486b91de
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.04 ms (jitter: 1.07ms, low: 3.50ms, high: 5.94ms)
Download: 29.30 Mbps (data used: 42.9 MB)
101.97 ms (jitter: 60.22ms, low: 4.37ms, high: 778.87ms)
Upload: 45.58 Mbps (data used: 77.1 MB)
129.66 ms (jitter: 53.44ms, low: 9.31ms, high: 952.69ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/ddd3f2c9-d01f-4ec8-9c03-933d6529b3dd
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 4.66 ms (jitter: 0.32ms, low: 4.41ms, high: 5.06ms)
Download: 45.88 Mbps (data used: 68.9 MB)
63.89 ms (jitter: 40.68ms, low: 4.73ms, high: 321.26ms)
Upload: 5.66 Mbps (data used: 6.8 MB)
640.91 ms (jitter: 111.90ms, low: 17.64ms, high: 2653.55ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/36510257-0aca-4cd0-bc48-1445511c2c5d
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.85 ms (jitter: 0.43ms, low: 3.39ms, high: 4.16ms)
Download: 3108.63 Mbps (data used: 4.1 GB)
13.49 ms (jitter: 6.36ms, low: 2.44ms, high: 86.08ms)
Upload: 2281.84 Mbps (data used: 3.7 GB)
17.40 ms (jitter: 10.83ms, low: 4.09ms, high: 97.04ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c26a7a03-05a1-4550-8967-81ffea39d0ce
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.22 ms (jitter: 0.41ms, low: 2.82ms, high: 4.02ms)
Download: 2992.11 Mbps (data used: 5.3 GB)
11.95 ms (jitter: 5.18ms, low: 3.25ms, high: 31.32ms)
Upload: 1367.98 Mbps (data used: 669.7 MB)
21.42 ms (jitter: 2.24ms, low: 3.29ms, high: 27.00ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/4ba8fa3e-eaa8-4225-8ade-236a2b32f6fd
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.29 ms (jitter: 0.36ms, low: 3.11ms, high: 3.74ms)
Download: 2802.93 Mbps (data used: 5.0 GB)
12.95 ms (jitter: 5.73ms, low: 4.23ms, high: 36.05ms)
Upload: 1832.09 Mbps (data used: 3.0 GB)
18.30 ms (jitter: 15.79ms, low: 6.02ms, high: 170.99ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/a7eae226-4ba6-4689-a62b-5c864b2e5762
same issue, my 6ghz is not always readily available. I have to turn off WiFi on my phone and on a few times to detect 6ghz. It seems like its not always on and broadcastingOther than the wireless mesh limitations (only 5GHz used as the backhaul), so far I only encounter one issue with TP-Link Archer BE805 in single router mode, from yesteday to today with all the testings.
Somehow 6GHz SSID disappeared and I have to reboot the router to get it back. Strange. This happened once in all my testings. I will need to monitor.
FW already upgraded to latest version.
Firmware Version: 1.0.12 Build 20240819 rel.66201(5347)
Hardware Version: Archer BE805 v1.0
There is a newer firmware version which is weirdly only available on their forum. 1.1.x series instead of 1.0.x series.Other than the wireless mesh limitations (only 5GHz used as the backhaul), so far I only encounter one issue with TP-Link Archer BE805 in single router mode, from yesteday to today with all the testings.
Quite a few fixes. Improved my speed a little
But can't downgrade once installed.
h_ttps://community.tp-link.com/en/home/forum/topic/719948
