withoutDo you go for glass protector with the camera hole punch or not?
smart switch everythingYou guys usually setup clean as new phone or using smart switch transfer everything from old to new ah?
https://e.tb.cn/h.TmnANuQvKLyzi4g?tk=BjhXeVLv5uRWhere to buy this Smartdevil tempered glass ? Had enough of Whitedome. Though is good, but have to depend on installer skill.
I don't like dust at camera area. I will go without punch holeDo you go for glass protector with the camera hole punch or not?
How about for long time iPhone user and first time switching to Android via S25U? What is the best approach? Thank you.smart switch everything
I would recommend a clean install. Hand on experience to try everything.How about for long time iPhone user and first time switching to Android via S25U? What is the best approach? Thank you.
Thanks. Does it mean Whatsapp will not have historical messages? And in my case a lot of them actually are important to move to the new phone.I would recommend a clean install. Hand on experience to try everything.
Thanks, carting out.
I remember seeing a setting in whatsapp that u can transfer chat history to androidThanks. Does it mean Whatsapp will not have historical messages? And in my case a lot of them actually are important to move to the new phone.
Isn’t it comparable to Samsung store but Samsung store gives 2 year warranty while your link only give 1 year warranty.
Will shopback discount be tracked if you buy through Samsung Shop App?
mine is being trackedWill shopback discount be tracked if you buy through Samsung Shop App?
