Nvidia RTX5000 up to +30% better than RTX4000 (only!)
ahbard
i got my 4080 for $600 on carousell... sold my 4070ti for $860 after that
600 for 4080 good price sia. For the 5000 series, if given a choice, I will get the 5070ti instead.
Performance should be close to 5080 at $250 lesser..
BlackWing1977
Cheapest RTX5090 on Dynacore list... just $1 short of $5000....
Wow.... that is already more than my whole PC I build 2 years ago... :sick:
BlackWing1977
and perhaps don't use or minimal use of RT, plus play at 1440p instead of 4K ......
Yeah.. just make do with whatever you have on hand... still using AMD 7900XTX.... and I dun even bother buying CyberPunk.. which I feel is basically a tech demo by Nvidia... :sick:
soreloser
Someone sold you a GeForce 4080 for $600?
Hard to believe unless it has defects
been using quite awhile already, almost 3 months with no issues at all. UV at 2.595GHz@.935V, 50-55C max while gaming. Just got really lucky, cause the guy request that i deposit first, but it ended up fine. Don't recommend to do that though, easy way to get scammed.I just see that he has good reviews so I went for it and got lucky. Usually ppl will snap that up in minutes, need to constantly check carousell for deals like that, most ppl dont have time for that.
R6exR6
I pre-ordered Cyberpunk but have yet to play it coz my mobo died that same year. Guess I'll play it in 2027 when the 6090 drops, coz skipping disappointing 5090. LOL
Yongkit
Anyone encountering this issue? After i installed the 5080, i encountered these issue
1. Will stuck at VGA white led with no display and need to boot again to load into window.
2. Screen will randomly turn black for 1-2s and back on.
3. PC will random reboot with no BSOD.
Thought connector or card loose. secure it again and issue persist.
Thought could be my seasonic psu issue but psu only 2 years old and no issue before installing new gpu.
In the end update my x870E mobo bios and issue seems to go away. The AGESA got updated and probably fix it somehow.
Also update the chipset driver if not yet
kappak
Youtube stock alert-amazon/bestbuy/newegg
9800x3d march
5070/5070ti 20th feb
5080/5090 already 1day no stock update
