Maybe my area have less bandwidth for upload or it could be BT10 issue![]()
This is my speedtest for M1 6Gbps.
I switched to M1 server but it's still the same result.Try using M1 server.
It is intermittent. If you're lucky, it works.Yay, the WAN speed test for BT10 has been reinstated this morning.
Seems like app and web GUI has API issue with firmware after firmware update and is fixed by an update to the app. The speed test using web GUI is still unavailable as of now. Good that Asus' backend team is actively sorting out issues.
Using Asus appYou test using speedtest app or website?
seems like it..is it just me or the 29.90 for 1gbps is only for new sign-ups.
hence existing customers who are recontracting are still stuck to the higher prices?
yes you are right. The $29.90/mth is only valid for new sign ups. For recontract customers, they will push customers to sign 2.5gbps at $39.90/mth.is it just me or the 29.90 for 1gbps is only for new sign-ups.
Hmmm where do you see 32.90 for 6gbps?seems like it..
last check 1gbps renew contract still need to pay $40.65..
only upgrade to 6gbps can lower to $32.90 with free wifi 7 router, if given the offer.
or 10gbps @ $50.90..
Targeted customers will receive an email from M1 for recontract, 6gbps for $32.90/mth.Hmmm where do you see 32.90 for 6gbps?
in any case, 3gbps and above only at selected location for now.
received the recontract offer from M1 via email.Hmmm where do you see 32.90 for 6gbps?
when did you receive this? hw far was you from your contract end date?received the recontract offer from M1 via email.
my contract ends 28 Feb 2025.when did you receive this? hw far was you from your contract end date?
I tried several times today using Samsung A70, S22 & S25U. It works every time except for S22. For S22, I need to delete and reinstall the Asus router app to get it to work even though the app was already updated to the same version as the rest. You may want to try with a different device or reinstall the Asus router app.It is intermittent. If you're lucky, it works.
Most of the time, it just says 10Gbps up and down.
Both for the App as well as Web UI.
Perhaps it needs to load this speedtest app from ASUS whenever we access this function.
And most of the time, perhaps the ASUS servers are too busy.
Didn't take screenshots, but recall In the handful of times which I've successfully accessed this function, the upload speed is slower than testing from my iPhone. Likely CPU too weak.
Even the web UI itself seems very sluggish by today's standards.
nice. try pure 6ghz wifi 7 band, see of there is any difference.Speed test using Samsung S25 Ultra and MLO (5 & 6Ghz) about 1.5m from the main router:
It is probably, temporarily out of stock. Wait a few more days, and check againDoes this mean no more ZenWiFi BT10 with 6 Gbps even if ready to top up?
