Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    204
Fellowes
Pitaka, very slim and nice.
tcmean
btw a headsup if anyone use swipe from bottom for navigation bar.
currently navistar is disabled in goodlock so u can only choose buttons or swipe from side :mad: (n)
i'm trying to make all the icons n buttons smaller , its like made for old old ppl with lao hua eyes or something . the words n icons super big and occupy so much of the screen for no reason.
There is actually updated version of NavStar in Goodlock for One UI 7. Just somehow Galaxy Store is still not showing the new version yet for us, so have to side load for now (if you are willing to)
https://www.apkmirror.com/apk/samsu...?key=ab141684b83726d57818e2a1ff141db054619d4f
subisisniki
It will affect image quality. And last time I use the ring kind, when removing, the adhesive peeled off a bit of the paint on the camera ring. Some more this time the camera ring is bigger, better not. If really want, get those type that is just one piece of glass. But hard to find... Need to search taobao.
But my s23u naked for 1.5 years... Don't see any scratches on the lens le
Wah naked ar... How u manage to do that without dropping
eq2addict
i saw some utuber use fine lock , i download finelock ( android play store) ,trigger navi star. uninstall fine lock , then got the prompt to update navistar in galaxy store ( then i can use with good lock) 🤣 seibeh convoluted
marshy
Do yall keep seeing a pop up at bottom of phone saying...
Place Bluetooth device near phone or check if its in pairing mode.
It keeps popping up and I can't figure out how to get rid of it.
eq2addict
u got device that is in pairing mode nearby issit ? or tomorrow get chat support to figure out what is the problem. so far ok for me. i pair fitbit & 2 bt headset so far.
trenzterra
My Navistar can work leh. But then I port over from s23u thru smart switch
Kerrlyfries
anybody know how to get back the one ui 6.1 swipe gestures on the s25? i used NavStar to do it on my 24 before, but option not available on s25
rharish_21
HomeUp also seems to missing from Good lock.
And side note does any one feels the widgets has been awful on One UI 7. Not sure why they killed and made it so bad.
trenzterra
One hand operation+?
Or you mean the bottom swipe. In Navistar you just select advanced settings then go to settings and enable
SECTORTWO
Yah! The Samsung clock and weather apps seem to have lost their ability to have transparent backgrounds...wth!
Oddly enough, my old "HD widgets" app that got broken by Android 14 (the time widget and stuff doesn't update in the background) seem to be working again in Android 15. Now just have to find a replacement for my news widget that isn't compatible...argh.
