Recommendations for Mini PC?
ichinisan
Looking for a mini pc which is sufficient enough for regular daily usage. Web browsing, movies, YouTube, MS office etc.
Budget would be around $150 to $250.
Is it also possible to use my current HDD in my PC on the mini PC? Some mini PCs have a slot for the HDD right?
DJ Pork Chop
alot of these mini pc, due to size restrains might only support 2.5. some even forgo sata and just use m.2.
think would be good to show some pic or model so people know ur mini how mini
ichinisan
Currently using those mid tower PC. 2.5 HDD.
Thoreldan
SimpleToo
It technically possible to use ur hdd on your new pc… but chances are u will need to buy a new enclosure… which u can get for less than $10 on shopee
given your limited budget what thoreldan recommended seem like a good deal… just note that the cpu wise is on the lower end… but should be able to handle your needs…
Project_Xco
On amazon, search for Trigkey or Beelink.
For your budget, can get N95 chipset or the better N100 chipset. I use N95 for a year and it is sufficient for general usage like u mentioned.
ichinisan
I do have a Samsung EVO SSD which I think it should be able to fit in those mini PC expandable slot? It is about 7mm thick.
ichinisan
Thanks. Will go take a look.
Which N95 mini pc are you using?
Scp173
My 2nd gen intel from lik 10 yr ago can do all ur needs
U can get for below 100 nowadays from carousell if u dun need mini lol
Y spend 150 when below 100 can do wad u need except not mini
SimpleToo
Which Samsung Evo ssd u are talking about? Is it the long NVME ssd or the 2.5 SATA ssd?
also depending on your mini pc modal u can swap the ssd within with ur existing ssd… if just to expand it depending on model u buying… at least the recommended modal I didn’t see any expandable slot…
caterham7
https://www.amazon.sg/dp/B0DJX54LRX
$169 currently
8/256 n95
Re: connecting existing hdd, check what interface your hdd is using, then see if supported by the mini pc.
Alternatively, can buy a cable and connect externally. This depends on whether the hdd supports this
coyote
There was a long thread on mini PC in this forum... Maybe ts can search for it....
ichinisan
It is the 2.5 SATA SSD.
