Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    202
ahtea
Just talked to the whatsapp agent. My 5th Feb preparing order status, Agent say it will be delivered from 14th Feb onwards only. Sxxcks man! He say cannot expedite or change to self collect
You ask him lo. From 14th is vague. Can be 14th itself or maybe months later. Samsung needs to give a date range for your delivery ma.
gapboy
Parka
KeYoKe
https://www.phonearena.com/news/Som...-phone-because-of-overheating-issues_id167427
Does your phone had any overheating issue? If so what brand will you choose?
For telcosz can it be exchanged?
I saw u ordered from ST liao right? If so, stop worrying and just use it. Worry here and there for what? If so worried, just dont unbox it and sell it off. A device is to ease your life, and not give you more reasons to worry.
Life is short to keep worrying about such unimportant things. Move on bro
Side qn: you are the famous gabriel? Cos i saw your past postings....very.....
Cryogenist
The OneUI 7 like not that robust/optimized yet.
Managed to hang it 2 times already under heavy load/usage.
Cryogenist
I compare photos from S25U and S23U... S25U seems quite a bit better. Even the 5x zoom at 10x, better than S23U. Ultrawide also pretty good
The ISP processing is significantly more refined now compared to even the S24U.
And the 50MP 0.6x is really producing way better IQ and sharpness than the old 12MP sensor and its processing.
gapboy
Is it true that for first few days the battery will drain quite fast ?
About 3 days the optimization will completed anyway during those few days mine last through the day and 4-5 hrs screen time on Ultra
elmariachi
Anyone knows if installing the Homeup apk would prevent you from using banking apps due to apps installed outside the store?
MasK
True..
There will be minor bugs here and there.
I had 2 app shortcuts which points to secure folder. They were placed in a home page folder. Overnight, these shortcuts disappeared. Strange..
Btw,
Anyone using the app DynamicSpot? Does this app clash with banking apps (due to accessibility settings)?
