Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    209
eq2addict
google drive not enough for my usage le..... that means i need to subscribe for one month for google drive for the purpose of this transfer?
whatapp media can be copied directly from whatsapp folder to where u want to store it. if u have a lot of ahem videos,
amazingone
yes thats correct due to the UI changes. Looks like IOS ?
The data upload download arrows are gone, really looks like iOS status icon but the 5G I feel is too bolded compared to other status bar icon.
ahtom82
you mean copy all the files from old phone to new phone, then directly restore from phone? can it work? cause last time i try with other samsung phones cannot work.
ahtom82
My wife's transfer was also smooth. (using wired Smart Switch)
Oh how did you do it? for whatsapp it works?
you mean you use smart switch to transfer app over first, then only go in whatsapp and restore again? i'm confuse....
eq2addict
mostly whatsapp backup size is very big due to video files . ppl share u and u share ppl is all dump on the phone. just copy the video files out to a hdd or new phone , same for the photos u want to keep. then after that disable media backup. that will reduce ur backup size.
just imagine ur phone is a PC . access the path n copy out can already.
DigDub
:D
Citiguy
I am not sure of the process, I'll need to ask her.
