- Jul 29, 2003
yes missing from the default when dont swipeHmm but you don't swipe down still don't show up wor
whatapp media can be copied directly from whatsapp folder to where u want to store it. if u have a lot of ahem videos,google drive not enough for my usage le..... that means i need to subscribe for one month for google drive for the purpose of this transfer?
My wife's transfer was also smooth. (using wired Smart Switch)Has the whatsapp restore bug been fixed?
The data upload download arrows are gone, really looks like iOS status icon but the 5G I feel is too bolded compared to other status bar icon.yes thats correct due to the UI changes. Looks like IOS ?
you mean copy all the files from old phone to new phone, then directly restore from phone? can it work? cause last time i try with other samsung phones cannot work.whatapp media can be copied directly from whatsapp folder to where u want to store it. if u have a lot of ahem videos,
Oh how did you do it? for whatsapp it works?My wife's transfer was also smooth. (using wired Smart Switch)
Thought u like take pictures, should go for ultra...cam is good.
Only when you pull down the quick panel it displays the icons now. On homescreen it only displays the basic information which is fine because it keeps everything much cleaner.wait , how u get the volte icon sia.
For pic taking I got sharp R9 pro liao. This one more for exercising, small can carry around easier.Thought u like take pictures, should go for ultra...cam is good.
you can see VOLTE icon briefly if you off / on between wifi & mobile networkOnly when you pull down the quick panel it displays the icons now. On homescreen it only displays the basic information which is fine because it keeps everything much cleaner.
Another fan of navy blue.. YAY
nice and chio.
I am not sure of the process, I'll need to ask her.Oh how did you do it? for whatsapp it works?
you mean you use smart switch to transfer app over first, then only go in whatsapp and restore again? i'm confuse....
My 2nd favorite color after coral red this year...same also not available for ultranice and chio.
Yeah the itch unbearableHopefully can get fast .... wait until damn sian liao ....
Ohh no wonder. Thought it was missingOnly when you pull down the quick panel it displays the icons now. On homescreen it only displays the basic information which is fine because it keeps everything much cleaner.
